Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Old 10-27-2009, 09:07 PM
fullbore1 is on a distinguished road
Default More wiring???
Figuring full load at 55 amps (bigger elements) L1 and L2 on separate breakers. So looking at the following diagram, if L1 is wired directly to the breaker through the plug and L2 is through the SSR does the SSR see the full current (55 A) or only the current supplied through the L2 (27.5A) leg? Also what good is the 4 wire system if the neutral and the ground are tied in the breaker box?
Michael Polizzi
Full Bore Karting
KartRaiser
Old 10-27-2009, 09:24 PM
Brintiff is on a distinguished road
Default Re: More wiring???
Each leg is going to pull 50 amps (at 240) , common mistake is to think a 50 amp device draws 25 amps per leg. Your SSR is going to see 50 amps on the one leg. Why are you not breaking both legs with the SSR? Maybe it's an SSR thing? I refuse to use them, I want something that 99.9% of the time is going to fail in the "open" position, like a contactor, having an SSR fail and stay closed would keep me awake at night.
The neutral and ground only terminate in the same spot if it's in the "primary means of disconnect". What do you mean that L1 and L2 are on separate breakers? They MUST be on one 2 pole breaker.
Old 10-27-2009, 09:50 PM
ed_denu will become famous soon enoughed_denu will become famous soon enough
A good target for ssr's, breakers, etc. is no more than 80% rated load. Pushing 55 amps thru a 60 amp ssr is probably going to result in a short ssr life span, even if you have an extremely good heatsink.
While the neutrals and grounds(earth) both terminate at the main service panel(first disconnect) they serve two distinct functions. At subpanels, such as those in garages and detached building they remain separate. The neutral connection will carry return current from any device using 120 volts, such as the pid, lights, fan, etc. A Ground represents an electrical path, normally designed to carry fault current when a breakdown occurs within electrical equipment.
Brintiff, SSR's typically are single pole, so only one leg of the 240 volt supply is switched. All ovens, etc. should have a master disconnect that disables the oven when not in use. Concerns about failed close ssr's can be easily alleviated by using a high temperature alarm.
Old 10-27-2009, 10:09 PM
The diagram was for flow purposes only. I have a 75 amp SSR and needed to know if I could use 30A breakers or needed 60's also it looks like I need 6AWG wire for this correct?
Yes, I will use a master disconnect and an over temp alarm.
Michael Polizzi
Full Bore Karting
KartRaiser
Old 10-27-2009, 11:00 PM
As Brintiff pointed out, you need a double breaker of sufficient capacity to support the load. I'm not sure what the question is about using 30 amp breakers? If your load is 55 amps, you need a 70 amp double pole breaker and #4 wire.
Old 10-28-2009, 12:08 PM
In the past there I have seen two breakers tied together at the shut off switch for 220V supplies. But as pointed out I will get the double pole 75A. Thanks. The 30A was in the 30+30=60A thought pattern.
Michael Polizzi
Full Bore Karting
KartRaiser
Old 10-28-2009, 01:37 PM
PhredAre is on a distinguished road
Ed, The neutral and the ground are tied together in the main panel but I believe in a sub panel they are to be isolated from one another to prevent ground currents from running on the neutral in the avent that the ground fails.Just a thought. Fred
  #8 (permalink)
Old 10-28-2009, 11:17 PM
Fred, You are correct. I thought I noted that in my first post, but perhaps I wasn't clear. A very good point either way.
  #9 (permalink)
Old 10-31-2009, 08:29 AM
philipd's Avatar
philipd is on a distinguished road
Dumb question here: why doesn't a 240 circuit have a neutral? Does one leg act as a neutral for the other leg?
'09 Kawasaki 500 LTD
  #10 (permalink)
Old 10-31-2009, 10:36 AM
SCOTTRODS is an unknown quantity at this point
It's not a dumb question.... It is apparent there's not much electrical knowledge in your life though. That's nothing to be ashamed of at all.
a 220/240 circuit is 2 110/120 hot legs, and a neutral (3 wire),.... in later model systems, there is also a ground (4 wire).....
<edit> I forgot to point you to the first post - it shows a 4 wire set-up <end edit>
NEED HELP With Wiring snowhoundxp Oven Building Forum 3 08-26-2009 11:32 AM
Wiring goincrzy Oven Building Forum 12 02-03-2009 08:59 PM
need to buy wiring?? cjlee Oven Building Forum 1 09-13-2006 02:38 PM
Wiring help now??? Evolved Oven Building Forum 5 07-06-2006 10:14 PM
Wiring 101 :) hvac36 Powder Coating Questions 3 12-23-2004 04:58 PM
