Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Old 10-30-2009, 01:03 AM
joebiggsly is on a distinguished road
Default Purpose of a fan
What exactly is the purpose of the fan? As I understand, it is used to homogenize the air, that is, ensure the air is the same temp. throughout the oven by "mixing" it. Do you actually want a draft? It seems to me that a draft would remove heat from the oven and cause a "stream" of cooler air and cause hot spots. I ask because I am trying to choose a fan, and the purpose will dictate which fan I choose. Thanks in advance.
Old 10-30-2009, 08:47 AM
FigureLLC's Avatar
Caswell Platinum Member
Default Re: Purpose of a fan
you're right about the mixing part. ideally you want the fan pulling air from the top of the oven and discharging it at the bottom. too much air movement is no good if you're blowing powder off the parts or if it's enough air to get your parts swinging and bouncing off each other. too much air movement won't create hot spots, though.
what size is your oven?
Len
Figure Finishing
www.FigureEngineering.com
866-900-4949
Old 10-31-2009, 08:35 AM
philipd's Avatar
philipd is on a distinguished road
Another question: should the fan draw in cooler outside air or should it just recirculate the air in the oven?
'09 Kawasaki 500 LTD
Old 10-31-2009, 10:38 AM
SCOTTRODS is an unknown quantity at this point
Re-circulate only.
Old 11-02-2009, 09:28 AM
FigureLLC's Avatar
yup, recirc. your oven should be vented, though. expanding air in the oven is coming out somewhere, which will be more than likely around the door seal if you don't vent it, and it'll leave ugly smoke marks around the door.
Len
Figure Finishing
866-900-4949
Tags
blower, draft, fan, purpose
Mineral Oil or Wd40 What's the Purpose? Cartierusm Anodizing Questions 1 07-29-2009 05:45 AM
General Purpose Blast Media? donafams Powder Coating Questions 11 06-29-2007 03:35 PM
Agitation purpose??? hurricaneracing Anodizing Questions 27 09-13-2006 11:06 AM
