I'm thinking about taking the parts out of a large free standing oven (cook stove) and using them in a new box (same cubic feet just a different shape). The reason for the new box would be hanging space. I would need a tall but narrower oven for the kind of parts I am planning on building. I was thing about 16"-18" wide X 14" deep and 30" tall Would the parts out of the large oven be enough to cure the powder? The oven was on a 50 amp breaker. I haven't got the stove yet. I do have a couple of old large toaster evens that might also work. I need to do this on a very low budget!! Any advice would be great and helpful Thanks dogwooddir1 |
Welcome to the forum.
This size oven won't require anything near 50 amps. I'm not sure what the function was for the oven you were planning to use as a donor, but it must of got to temp in a minute or 2. 18X14X30 is only a bit over 4 cu. ft. Even a single oven element typically rated at 3000 watts would heat this in 2-3 minutes. Actually for this size a 1000 watt 120 volt element(8.5 amps) would be adequate. I would use the toaster oven parts. Your biggest concern will be the ability to closely control the temperature. Last edited by ed_denu; 10-30-2009 at 03:27 PM. |
Thanks bikerdad46 |
Thanks again bikerdad46 |
This lets you calculate based upon oven size and temp desired.
BTU Calculator provided by the heater shop .com |
There's a better calculator imo than the heater shop one. It's excel based and listed in the BTU calculator sticky at the top of this forum. If you want to use the heater shop calculator, enter average insulation, versus good, for a better indicator of the watts required.
I also have kept track of the size ovens being build and the wattage people are using as a real life reference. Last edited by ed_denu; 10-31-2009 at 12:55 PM. |
| thinking of selling my pc oven | o1dakota440 | Oven Building Forum | 4 | 09-24-2008 04:32 PM |
| Anyone With A Used Oven Or Can Build A Oven For Me, Ohio | REVS | Oven Building Forum | 2 | 01-04-2008 12:15 PM |
| Thinking of an oven..... | vintagespeedwerks | Oven Building Forum | 9 | 10-08-2006 08:47 PM |
| Good oven shell for wanting to build your own oven | dannydone | Powder Coating Questions | 6 | 03-21-2006 11:40 PM |
| Oven, just thinking out loud | jjucius | Oven Building Forum | 4 | 10-22-2005 09:56 PM |
