Thanks for any assistance. |
How is the pid/contactor wired? What schematic was used. If the auto-tune completes, why are you running it multiple times? |
Thanks for the information. The PID and contactor are hard wired together. I just put a switch in-between so I could shut the oven off and still be able to program the PID. I figured out that if my oven is set at 380 degrees with the PID, a standard oven thermometer that I placed inside the oven will show 400 degrees. Not sure which is accurate. When the oven got to 370 degrees the contactor started clicking and continued to click and narrowed it into 380 degrees. The oven stayed at 380 but the contactor continued to click every several seconds and woudn't stop. So you're saying this is normal? Thanks.
Yes, absolutely normal. The relay contacts in the contactor will remain closed until the set temperature approaches. As the set temperature is reached, or near, the pid will begin cycling the contactor on/off to settle in at the set temperature. You might want to set parameter 'OT' to a value between 5-15 as with a contactor you don't want the electro-mechanical relay to cycle too frequently.
The difference in temperatures you are seeing could be due to many things, including placement of the tc. There is a temperature offset parameter(PSb) you can adjust if you feel the tc is reporting incorrectly Last edited by ed_denu; 11-05-2009 at 08:34 PM. |
| Neither grey dye working. | gcdrummer02 | Anodizing Questions | 5 | 08-02-2009 02:31 AM |
| need assistance finding piece of equipment | samtgallagher | Metal Polishing Questions | 7 | 03-17-2008 09:53 PM |
| Working with my new (to me) machine | felgenpolier | Metal Polishing Questions | 7 | 06-21-2007 02:27 PM |
| Vinyl working | destroyer125 | Anodizing Questions | 7 | 07-10-2006 01:38 PM |
| nothing is working | danderson | Electroplating Questions | 5 | 01-27-2005 01:31 PM |
