Results 1 to 3 of 3
Thread: Cellulose Insulation For A PC Oven
  1. #1
    pcbeachrat is offline Newbie
    Join Date
    Nov 2009
    Posts
    6
    Default Cellulose Insulation For A PC Oven
    Looking to get into PowderCoating soon,as I already have A sandblasting set up and alot of my customers ask me about powder coating all the time. I am A retired Paint Contractor with 37 years experience, but have never touched A PC gun in my life.After extensive research, and many trips here to Caswells, I have decided to now build An oven to powder coat from. I have alot of unopened cellulose insulation laying around and was wondering if this would be sufficient to insulate a PC oven with, providing it is packed in tight and 4 inches thick.Supposedly it has A higher flame retardent rate of common unfaced fiberglass insulation and I feel it will hold 400 degrees quite effeciently, but My main concern is..will the constant usage of 400 degree temperatures make this cellulose, "settle" or break down or anything of the sort?I have many more questions coming soon, but I will try not to flood you all with multiple questions concerning this build..Please let me know your thoughts on using cellulose Insulation on a PC oven..Thanks..
  2. #2
    ed_denu is offline Metal Finishing Guru
    Join Date
    Jul 2006
    Posts
    1,144
    Default Re: Cellulose Insulation For A PC Oven
    I don't recall anyone ever attempting to use this in an oven.
    Doesn't all insulation rely on air pockets to aid insulating properties, so I would be concerned about packing it in tightly. I guess I also would be concerned about settling and the possibility of small loose fibers making their way into the oven.
    Unless cost is the overriding concern, I wouldn't use the loose insulation.
  3. #3
    AnotherDano is offline Newbie
    Join Date
    Nov 2009
    Location
    Laramie, Wyoming
    Posts
    16
    If that's all I had, I'd consider using it.
    To avoid settling, think about using chicken wire, just like steel mesh in a concrete floor. The wire would hold the fibers in place and keep the material on the top from weighing down on the material below.
    Just a thought,, your results may vary.
Thread Information
Users Browsing this Thread
  1. Oven insulation
    By bikerdad46 in forum Oven Building Forum
    Last Post: 11-14-2009, 07:04 PM
  2. oven insulation
    By independentrider1 in forum Oven Building Forum
    Last Post: 01-04-2007, 08:41 PM
  3. oven insulation
    By djlaserob in forum Oven Building Forum
    Last Post: 12-02-2006, 08:50 PM
  4. Pregnant Oven Insulation
    By sab0276 in forum Oven Building Forum
    Last Post: 01-08-2006, 08:13 PM
  5. Roofing insulation oven?
    By knightda8 in forum Powder Coating Questions
    Last Post: 02-07-2005, 09:48 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
