Originally Posted by
pyroracing85
Okay. I have been throwing this one out there.
So I read the best way to do it is to start with "metal studs".. I am assuming just square tubes 2"x2" with a 1/8" wall thickness. When people refer to metal studs they are referencing the studs used in building construction. These can be found at HD, Lowes or most drywall suppliers. They are basically the dimensions of a 2X4 stud.
Is that to much over kill?
Then you are to frame it on the inside and outside with sheet metal and insulation in between? YES
