A 120 volt toaster element around 1500 watts will heat this size oven just fine. Probably under 10 minutes.
A 3000 watt 250 volt element would probably also work running on 120 volts if a heat up time of 15 minutes or so is acceptable.
Are you building the walls thicker than 1"? One inch won't allow for much insulation.
LinkBack URL
About LinkBacks
