Your elements then on 240 volts are going to draw around 11 amps each(2600 watts), so I would look for a 40 amp ssr or contactor. Either would work. There are many pids available from the low end to the higher end ramp/soak models.
It mostly comes down to what you want to spend and/or what type control you desire. Just be sure to match the pid to the ssr/contactor input voltage requirements.
LinkBack URL
About LinkBacks
