Results 1 to 10 of 10
Thread: Electronics Material list?
  1. #1
    madmak is offline Newbie
    Join Date
    Jan 2010
    Posts
    6
    Default Electronics Material list?
    Hello all. Im new here. found this site while looking at building a PC oven... Great site. I can handle the oven box build myself, but the electronis is the hard part. So can some one help me with a material list? Pids ,ssrs, fans. elements.
    Specs:
    size...4x4x6
    volts...220
    So what do i need to make heat? . Any help will be great. James
  2. #2
    tedsfab is offline Amateur Metal Finisher
    Join Date
    Aug 2008
    Location
    tower city pa
    Posts
    73
    Default Re: Electronics Material list?
    hey james ,
    for that size oven about 10kw would get the job done , fan would not really be needed if you place the heaters on the side walls , if your looking for a control box that is pre wired and ready to install take a look at the link below . it includes the pid , contactors , temp probe . basically all you need to do is run your wires into it and out of it . all the components inside are already wired .
    i also have heaters and door seal , and wire listed for guys building there own ovens .
    if you have any questions just ask
    Store
    thanks ted
    visit our website for all your oven building parts
    www.tedsfabrication.com
    www.thepowdercoatingforum.com
  3. #3
    AntaresArms is offline Newbie
    Join Date
    Dec 2009
    Posts
    20
    Ted,
    When does the high temp wire need to be used? I have seen many ovens that seem to just have normal wiring. Also, on a door that is 4.5 would 2 clamps be enough or should I use 3?
    I just picked up an oven and might redo the electronics and add some finishing touches to it like better seals, clamps etc.
    You also mentioned that a fan would not be needed if the elements were on the sides. On my oven, they are on the bottom, what is the best way/location to install a fan and to keep it from blowing powder off of parts?
    Thanks, Jason
  4. #4
    Join Date
    Jan 2010
    Posts
    6
    THHN wire is ( i think) rated for 600 degrees F .
    As im an electrian ,wireing up my controll box isnt a problem . I just like to know what parts Id need. Part # would be great. Ted do u sale seperate parts?James
  5. #5
    ed_denu is offline Metal Finishing Guru
    Join Date
    Jul 2006
    Posts
    1,148
    Quote Originally Posted by madmak View Post
    THHN is rate for only 194 degree F(NEC Table 310.13). You need something like MG wire where it enters the oven to the elements.
    The basic parts list is: pid, ssr/contactor, power block or terminal strip, wire. Basic pid would be something like the TET-612 or Auber Instruments pid. A step up would be the Auber ramp/soak model. A still better unit would be something like the Watlows. Lot's of choices, depends on the needs/wants, so there isn't a single choice with model number, just remember to match the pid specifications to the ssr/contractor input power requirements. As for ssr/contactor, imo it's a personal choice, but again remember to match to amperage draw of the elements.
    Other bells and whistles that can be added are interior light, fan, timer, alarms, indicator lights, etc.
    An easy solution for the fan is to install a switch in the circuit and only turn the fan on once the powder has begun to flow out.
  6. #6
    Join Date
    Dec 2009
    Posts
    20
    I have no wire that enters the oven, the elements are attached to the inside wall at the normal mounting plate. The rest of the element that has the male blade terminals passes through the insulation and just sticks out the other side. Do, I need to use the MG wire right at the elements? I don't mean to take over this thread, but no one has replied to my questions on the other one.
  7. #7
    Join Date
    Jul 2006
    Posts
    1,148
    Quote Originally Posted by AntaresArms View Post
    I would use the mg type wire until you are completely outside of the oven walls. I believed that all kitchen ovens use hi temp wire attaching to the elements.
  8. #8
    Join Date
    Jan 2010
    Posts
    6
    ask all u want .... im learning right along with u.
  9. #9
    Join Date
    Jan 2010
    Posts
    6
    Quote Originally Posted by ed_denu View Post
    dont know where i got that # at .... been awhile sicne i read thhn. thank for the correction.
  10. #10
    scottluckman is offline Platinum Member
    Join Date
    Jan 2010
    Posts
    3
    I think THHN is rated for 600V not 600 degrees. I'm an electricaian also, and I would use an element that has a screw in it instead of a male blade connector. I have seen a ton of GP contactors use the female connectors and it will just melt the wire and terminals if overloaded. Use a fork or ring terminal with #10ga PTFE wire and solder terminal to the wire for a little extra insurance. PTFE is good for 482 degrees and you should not have that much heat inside your oven walls. Just my 2 cents.
    Scott
Thread Information
Users Browsing this Thread
  1. Anodizing list?
    By MackGerard in forum Anodizing Questions
    Last Post: 01-13-2009, 07:02 AM
  2. Need a list please.
    By Empire03 in forum Anodizing Questions
    Last Post: 12-28-2007, 07:33 AM
  3. Alloy list?
    By jc88usus in forum Anodizing Questions
    Last Post: 08-16-2007, 01:23 PM
  4. Starter List
    By grommit in forum Powder Coating Questions
    Last Post: 03-30-2006, 03:22 AM
  5. Interesting electronics idea...
    By NeoMoses in forum Anodizing Questions
    Last Post: 12-15-2003, 12:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
