Either mineral wool or unfaced fiberglass insulation will work. They actually have the same insulation value, but the mineral wool has a higher temperature rating. Either can be cut to the dimensions needed to fit in the oven walls.
Galvanized sheet is what is most often used for oven construction, both inside and out.
LinkBack URL
About LinkBacks
