Results 1 to 3 of 3
Thread: Oven Temperature Issue
  1. #1
    bdanford is offline Platinum Member
    Join Date
    Oct 2009
    Posts
    1
    Default Oven Temperature Issue
    Just got done building a curing oven, and I think we have most of the bugs working out, except 1. We are using a TET612 PID and the temp on the ambient temp (PV) is reading WAY off from the actual temp. Its a type K thermocouple. When the PID reads about 88F degrees, I'm getting almost 200F from both a oven hanging thermometer and a hand held infrared. Looking over the TET612 manual, I see that they show a connection/resistor from terminal 8 and 10, but I never see anything that says that its needed, or what the value should be. Any help you can give me on this would be great. This is pretty much the last think we need to get resolved.
    Thank you very much in advance!
    Brian
  2. #2
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Default Re: Oven Temperature Issue
    Quote Originally Posted by bdanford View Post
    Brian
    Sounds like you need to read the display again.... in Fahrenheit..... 88 degrees Celsius is about 190 Fahrenheit. Maybe change your settings to read out F instead of C
    EMAIL scott@scottrodspc.com
  3. #3
    ed_denu is offline Metal Finishing Guru
    Join Date
    Jul 2006
    Posts
    1,148
    Scott may be correct, check the 'corf' parameter to make sure it'e set to 'F'. The resistor you reference is not required for a K thermocouple. Make sure 'inty' is set to 'K'.
Thread Information
Users Browsing this Thread
  1. candy issue
    By Big3 in forum Powder Coating Questions
    Last Post: 03-11-2009, 04:01 PM
  2. Issue with buffing!!!
    By Qmyster in forum Metal Polishing Questions
    Last Post: 11-17-2007, 09:17 AM
  3. oven temperature tolerance
    By FigureLLC in forum Oven Building Forum
    Last Post: 09-20-2007, 05:12 AM
  4. oven heating issue
    By gaskincrew in forum Oven Building Forum
    Last Post: 04-07-2006, 01:49 PM
  5. Newbie and oven temperature ?
    By Netnut in forum Powder Coating Questions
    Last Post: 05-26-2005, 09:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
