Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Out side the box oven build
  1. #1
    bagley2000 is offline Newbie
    Join Date
    Aug 2009
    Posts
    16
    Cool Out side the box oven build
    This is a modgular oven that i am building. It can be a 2' x 2' , 4' x 4' , 6' x 6' , 4' x 8' or a 2' x 8' box. We are building it in 2' x 2' wall sections that can be stacked and pined together. To insulate the walls we have a 1/4" stand off of screen and wire mesh and filling the walls with vermiculite. Will be sheeting with 24 gauge galv steal inside and out. Please if you have any advice or conserns about this build please let me know for this is my first oven build and all the help would be nice.[IMG][IMG][/IMG][/IMG]
  2. #2
    Join Date
    Aug 2009
    Posts
    16
    Default Re: Out side the box oven build
  3. #3
    Join Date
    Aug 2009
    Posts
    16
    Out side the box oven build-0331102325a..jpgOut side the box oven build-0331102325b..jpg
    Just trying to add attachments to the post above.
    This is one of the 2' x 2' pannels under construction.
  4. #4
    BigJayDee is offline Amateur Metal Finisher
    Join Date
    Jul 2008
    Location
    Lee's Summit, MO ( KC )
    Posts
    61
    couple of questions what is the temp rating of your insulation (I am not familiar with what you have) ?
    How large of a wall stud are you using ?
    I am not sure that 24 guage is going to be thick enough for the inside, I am willing to bet that the outside of your oven is going to be extremely hot !
  5. #5
    Join Date
    Aug 2009
    Posts
    16
    Thermal Insulation--Vermiculite has been used for over 50 years for insulation in attics, walls, and high temperature industrial applications. In recent testing, vermiculite masonry insulation used in a standard 8" lightweight block performed better than urea formaldehyde foam polystyrene beads, and polystyrene inserts. Generally vermiculite will increase the total insulating value of a block wall by 35% to 60% depending upon the properties of the concrete block.
    Permanency--Vermiculite is a naturally occurring mineral and has a sintering point of 2300o or (1260o C). Once in place, this product has very minimal settling properties. Vermiculite is free flowing and will fill and insulate all voids.
    Non-Combustible--In testing following the ASTM E-84 tunnel test, vermiculite has no flame spread, no fuel contributed, or smoke developed
    Got this info from here SCHUNDLER COMPANY--Vermiculite Masonry Fill--Loose Fill Insulation
    Can get 4 cu ft bag for 14.00 a bag
  6. #6
    Join Date
    Aug 2009
    Posts
    16
    This is the back wall
    Attached Thumbnails Attached Thumbnails Out side the box oven build-back-wall..jpg
  7. #7
    bikerdad46 is offline Amateur Metal Finisher
    Join Date
    Oct 2009
    Location
    Cunningham, KY
    Posts
    142
    Quote Originally Posted by bagley2000 View Post
    Hello bagley2000
    What is the R value of the insulation at 2 3/8" ? Also If I was building it I would use 3 5/8" 20 ga steel studs. It would give you more room for the Vermiculite. I don't think the vermiculite has enought R value
    for the oven. I know years ago it was used in block walls but the inside of the buildings were furred out and insulated with fiberglass or foam insulation. Just check the R value and make sure it's at least 13 at 2 3/8".
    bikerdad46
  8. #8
    Join Date
    Aug 2009
    Posts
    16
    Thank you bikerdad46 i checked the R value and it will not work at 2 3/8" it gives you abuot an R 6. I still like the idea of using Vermiculite just for the fact it is a loose fill and will fill all the voids in the walls. I think the new plan will be to double my wall thickness that would rase the R value to 12.
    Thank you for the help
    bagley2000
    Attached Thumbnails Attached Thumbnails Out side the box oven build-thick-wall..jpg
  9. #9
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    bagley2000
    i m not sure why you want to use vermiculite , the r value is very low and the fact that it will fill all the voids in the walls is not very important because if you are building simple 2x2 sections it is very easy to fill them completly by using some rockwool or mineral wool insulation .
    when lining the walls , will you be lining the whole wall in 1 piece or are you thinking of lining every 2x2 sections separate
  10. #10
    Join Date
    Aug 2009
    Posts
    16
    Smile Re: Out side the box oven build
    Yes i will be insulating every 2 x 2 x 4 3/4 section separate. The plan is to build several of these 2 x 2 sections and build any size oven we need. The vermiculite is just what we found in town for 11.00 dollers a bag.
    Attached Thumbnails Attached Thumbnails Out side the box oven build-0406100806..jpg   Out side the box oven build-0406100803..jpg
Thread Information
Users Browsing this Thread
  1. Good oven shell for wanting to build your own oven
    By dannydone in forum Powder Coating Questions
    Last Post: 09-13-2010, 12:32 PM
  2. New Oven Build II
    By simk in forum Oven Building Forum
    Last Post: 03-18-2010, 07:03 AM
  3. New Guy Here. Oven Build.
    By Zigeuner in forum Oven Building Forum
    Last Post: 10-07-2009, 11:56 PM
  4. Anyone With A Used Oven Or Can Build A Oven For Me, Ohio
    By REVS in forum Oven Building Forum
    Last Post: 01-04-2008, 11:15 AM
  5. i want to build an oven
    By suprtong in forum Powder Coating Questions
    Last Post: 03-11-2005, 01:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
