Results 1 to 2 of 2
Thread: Question about PID controller
  1. #1
    Radiant is offline Platinum Member
    Join Date
    May 2010
    Posts
    2
    Default Question about PID controller
    I'm looking at an Omega PID controller, mostly because you can get free software that works with it. Apparently you can hook it up to a computer to look at more complex ramp/soak temperature profiles, which would be useful for my applications.
    Controller:
    1/32 DIN Ramp/Soak Controllers
    I'm looking at using it with SSR's. You have to specify 1 of 2 different output options when you buy it: 1) "Dual output, DC pulse/relay, RS485" or 2) "Dual output, relay/relay, RS485". Would this controller work with the SSR's? If so, which option would be the choice to get, 1) or 2)?
    I'd also be interested if anyone has input or experience with Omega controllers.
    Thanks,
    Rob
  2. #2
    CarWiz's Avatar
    CarWiz is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Sep 2005
    Location
    South Texas
    Posts
    906
    Default Re: Question about PID controller
    Both work with SSRs. An SSR is a solid state relay. They can be ac controlled or dc controlled depending on the type you buy. If you buy dc controlled SSRs then buy the DC output controller. Make sure the SSRs you buy are compatible with the controller.
Thread Information
Users Browsing this Thread
  1. which PID controller are you using
    By 4x4fab in forum Oven Building Forum
    Last Post: 01-10-2010, 09:19 PM
  2. P.I.D Controller
    By sinr98 in forum Oven Building Forum
    Last Post: 10-04-2009, 10:19 AM
  3. Oven Controller
    By uricad in forum Powder Coating Questions
    Last Post: 07-14-2008, 09:49 PM
  4. New Controller
    By kcenicola in forum Oven Building Forum
    Last Post: 12-18-2007, 04:24 PM
  5. PID controller question?
    By Deecoat in forum Oven Building Forum
    Last Post: 11-04-2007, 11:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
