Construction of the Control Box:
After you have acquired the components for the oven build lay them out and determine the size necessary for the physical housing. If you have access to a drawing program these can be very useful in creating a scaled drawing for layout of the control box.
I’ve chosen to place the physical controls(PID, timer, switches, etc.) on the side of the control box rather than the lid or door. There are two advantages I see in this choice. By placing them on the side they are visible from the oven front so side access to the controls is not necessary. The other advantage is that if these components are not placed on the door, then there is no danger the wiring will be pinched by opening/closing the door.
The square cutouts for the PID and similar instruments can be made using a Dremel with small cutout wheels. Round openings are most easily made using step drills.
LinkBack URL
About LinkBacks
