Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: My NON-Folding Oven begins!
  1. #1
    Noob2PC's Avatar
    Noob2PC is offline Experienced Metal Finisher
    Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    376
    Cool My NON-Folding Oven begins!
    Well I have picked up the beginning of my larger oven. It will be 4x3x3 and I hope to generate enough $ to build my 24 x 24 shop in the back yard so i can then build a 8x8x4 oven. So far I have a total for $67.30 for the mineral wool and the stud. Plan on getting the material to skin it for free and use a $30 oven for wiring, controls and elements.
    12 Steel Stud's
    Mineral Wool
  2. #2
    Noob2PC's Avatar
    Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    376
    Default Re: My NON-Folding Oven begins!
    If I use an old oven door glass to make a window, can you take the part temp using a IR Temp gun threw the glass?
  3. #3
    AKStubby's Avatar
    AKStubby is offline Newbie
    Join Date
    May 2010
    Location
    Fairbanks, AK
    Posts
    19
    no the ir will read the temp of the glass. consider a remote thermo couple attached to part. that way you will know pretty exactly when your part reaches temp --- or a small peep hole you can open to stick IR in and get somewhat clear reading. ^not a big fan of IR for somewhat precision stuff^ good to use to get ball park and to find dead cylinders.
  4. #4
    Noob2PC's Avatar
    Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    376
    Quote Originally Posted by AKStubby View Post
    OKIES then I will not bother with the glass and make a trap door for the IR gun.
  5. #5
    SCOTTRODS's Avatar
    Join Date
    Jul 2008
    Location
    Garland, TEXAS
    Posts
    1,177
    Quote Originally Posted by Noob2PC View Post
    Make a trap door with the glass in it, so you can also watch for flow out to check on candies for coverage.... It's actually the best way to go if you can work it out.
    EMAIL scott@scottrodspc.com
  6. #6
    Noob2PC's Avatar
    Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    376
    Couple more Questions. Do I really need to insulate the bottom if I am setting it flat on a Concrete slab? If not how would I attach the seal for the floor part of the door? Should 2 elements be enough for a 5x3x3 oven?
  7. #7
    Noob2PC's Avatar
    Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    376
    Got my frame sorted out this morning.
    Attached Thumbnails Attached Thumbnails My NON-Folding Oven begins!-frame2.jpg   My NON-Folding Oven begins!-frame3.jpg
  8. #8
    Noob2PC's Avatar
    Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    376
    OK I got my 2x 3500 watt elements, the T-stat, and the 2 controls and power cord block from an oven. Now I need to stretch everything out so it all fits where I want to put it. What spec's do I need for the wire to my wiring? I know high temp but what gauge would be needed? and are there special connectors that I need to splice the wire? where can I look locally for the wire as I do not need all that much.
  9. #9
    Noob2PC's Avatar
    Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    376
    Well I got my sheet metal in for the inside. Also have the frame almost finished. Here is some sheet metal not being used for this project. also my controls and elements for this oven. yes I gutted a regular oven for them. no need to re-invent something that is already done. Enjoy!
    Joe
    Attached Thumbnails Attached Thumbnails My NON-Folding Oven begins!-sheetmetaly.jpg   My NON-Folding Oven begins!-sheetmetaln.jpg
  10. #10
    Noob2PC's Avatar
    Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    376
    Here is the Frame as of Now.
    Attached Thumbnails Attached Thumbnails My NON-Folding Oven begins!-frame4.jpg   My NON-Folding Oven begins!-frame5.jpg
Thread Information
Users Browsing this Thread
  1. Good oven shell for wanting to build your own oven
    By dannydone in forum Powder Coating Questions
    Last Post: 09-13-2010, 12:32 PM
  2. Pricing on Metal folding Chairs
    By robsrod in forum Powder Coating Questions
    Last Post: 03-22-2008, 12:31 AM
  3. So it begins..first powdercoating experience
    By JashGTP in forum Powder Coating Questions
    Last Post: 06-28-2007, 07:53 AM
  4. My new oven begins...
    By chromeitout in forum Oven Building Forum
    Last Post: 03-19-2007, 10:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
