Results 1 to 4 of 4
Thread: finishing help for my oven
  1. #1
    tricountykustomz is offline Platinum Member
    Join Date
    Jun 2010
    Location
    Yarmouth, Nova Scotia
    Posts
    2
    Default finishing help for my oven
    hello, i'm slowly getting to the final parts of my oven but need a little extra help on where to place things. first is the blower to circulate the air.
    in this picture you can see a horizontal peice i put in on the back wall..i was thinking that is where i'm going to mount my motor (it's a oil cooled 3 speed motor from a propane pizza oven for curculating air in those ovens) i have a couple regular 5 blade fans and 2 squirll cage fans (no houseings) i'm wondering if the regular 5 blade fan would work if it was mounted on the inside and set up so it would pull the air rather then push. also i'm wondering if i need a vent in the oven or seal it up air tight (or as air tight as possible)
    then my final question for now is i'm putting 3 -2500 watt elements on the bottom mounted on the walls. i've read about people putting heat sheilds over them. just wondering if someone could post some pics or something to i could see what's been done for that. thanks in advance
  2. #2
    Noob2PC's Avatar
    Noob2PC is offline Experienced Metal Finisher
    Join Date
    Mar 2004
    Location
    Greensboro NC
    Posts
    376
    Default Re: finishing help for my oven
    I'm building mine now, but I can't help with the blower as I am not going to be using one. I feel with a 3x3x6 area I do not need one. I am making mine as air tight as I can get it and will be installing a 1/2" pipe U mounted upside-down to act as a pressure relief. I am guessing that pulling the air up to the top and then having it slide down the sides would work but I'm sure someone with more Experience will correct me
  3. #3
    JTW37's Avatar
    JTW37 is offline Metal Finishing Guru Caswell Platinum Member
    Join Date
    Feb 2006
    Location
    Bristol, In
    Posts
    776
    Quote Originally Posted by Noob2PC View Post
    The whole idea to a fan, is to keep the hot spots to a minimum. It will make the temps in your oven more even from top to bottom. The vent pipe is also a good idea, as it will help to breath ( for the lack of a better word) and get the smoke out of the oven, so it don't settle on what you are curing. Black is bad for making smoke. You may want to reconsider.
    "tricountykustomz" As for the placement of your fan, mine has an intake at the top which is run down the back of the oven a short distance and back into the oven, with a rectangular tube running down the back wall toward the floor. This keeps the air flowing for even heating and not disturb the powder.
  4. #4
    Join Date
    Jun 2010
    Location
    Posts
    2
    alright, thanks for the info. i'm thinking of putting a small opening at the base around where the elements would be (small being 1" max) and two 1/2-3/4" openings in the top corners of the oven with a slide plate to be able to open and close them if i want. and then just have the fan on the back wall pulling air towards the wall (so i don't blow the powder everywhere) that way the air will be pulled from the middle of the oven to the back wall and around the outside of the oven.
Thread Information
Users Browsing this Thread
  1. Finishing.com
    By andy1954 in forum Electroplating Questions
    Last Post: 10-11-2008, 10:10 AM
  2. Gun Finishing ???
    By tbreaden in forum Other Metal Finishing Questions
    Last Post: 01-08-2008, 08:59 PM
  3. Replies: 26
    Last Post: 12-12-2007, 10:33 AM
  4. aluminum finishing
    By alnico4u in forum Other Metal Finishing Questions
    Last Post: 03-11-2006, 10:59 AM
  5. finishing question ??
    By dope1 in forum Metal Polishing Questions
    Last Post: 04-26-2004, 08:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
