Originally Posted by
missile150
This fall/winter I am going to start to rip apart my household oven and make a larger one with the top and bottom burners from the existing one. I am wanting to make it roughly 2 x 2 x 5 feet long (or tall). Will the two burners be enough from the existing oven to heat up this one? I am going to use metal studs, steel for the inside and out and 1 1/2" mineral wool for lining.
Also, should it be longer rather than taller? And if so, where would I place the two burners for optimal usage, at the bottom like if it was taller, or on the sides and towards the bottoms? Thanks.
