Originally Posted by
slammedxonair
Hello everybody, I just reveived my PC startup equipment and I am interested in building an oven and adding powder coating to my business. I have been reading around on a bunch of forums trying to gather as much info as I can. I send Teds Fab an email on Tuesday and I was just wondering about how long it takes to receive a reply back? But I will post some of my questions here to see If anybody here can help me out.
I have been looking at Teds control boxes listed on ebay as well as some of the other parts he uses on his ovens listed on his web site. Here are a couple questions I have if anybody can help out.
Are the 4, 3200 watt heaters the largest you can run with the 2, 40 amp magnetic contact relays, or would I be able to run 4, 3800 watt heaters on those relays? (2) 3800 watt elements would pull 32 amps at 240 volts. The 40 A contactors should handle this load without a problem. I plan to start out with powder coating but would like to add ceramics also a little while down the road, I like to plan ahead. I was thinking about possibly building a 4x4x6 oven (maybe 3x4x6) and adding in a insulated shelf maybe 2' from the top of the unit when doing ceramics. I have thrown some other numbers around as well in the calculators online to try and figure this out. Making the oven smaller for ceramics would obviously reduce the space required to heat and would allow the oven to heat faster. However, you may need to run the autotuning function when changing the oven dimensions.
Would it be possible to have 2 heater switches on the control box? 1 switch for the 2 main heaters for powder coating and 1 switch for the 2 secondary heaters for when I start doing ceramics? Or could all 4 just always run, cooler when powder coating and then they would crank up the heat with ceramics? When on, the elements will always output the rated wattage. The only way to vary the wattage would be to change the input voltage which pid's controlling contactors will not do. I personally don't understand the reasoning to have switches to turn on or off elements. The purpose of the pid is to control the oven temperature to the set point. IMO let the pid manage the elements. If you have concerns about the oven heating to quickly for PC, then you might look at one of the ramp/soak pid controllers.
Would it also be possible to run the 3 elements on 1 power switch and then 1 extra element on a second switch or would that require a different magnetic contact relay other than what Teds boxes normally use? This is not a big deal 2 and 2 would probably work fine rather than 3 and 1.
I would like to keep the amps under 40-50 max when powder coating but when doing ceramics it could go over that (I will probably add the 2 extra heat elements later on for ceramics but want to have the controls there ready to go.) Unless you plan on wiring the elements on separate circuits, you will need around an 80 amp circuit to support (4) 3800 watt elements.
I know I will also want to add a light inside and possibly a fan that Ted sells if it can withstand the ceramic temps. Does having a fan circulating the air effect the finish of the powder coating at all such as creating runs or anything like that?
Does Teds control box come with the connectors to connect the elements to high temp wire?
Thanks for any help.
