having enough IR lights to make the chassis think it's in an oven is certainly not necessary. As stated above, the "overlap" is actually expected in an IR situation due to the fact that it can only cure "X" amount of space in a specified time. Just as a general rule, move the light within 12" of your part, watch for a flow of powder and wait 10-15 minutes.... then move the light onto the next area down where you see that powder "half-melted" and start the process all over again.... it flows, start a timer, and so on and so on. Like I said before.... if you want a process that's a little bit quicker, then subtract one of the M2000's and add an M9000 in it's place (larger IR surface) to cut time down quite a bit. Workable area is still the general space of 12-16ish inches away from the light.
Let's take as a good example a past customer of mine that only did lock down rings for truck tires ( they go on rims that can be broken down). I had him hang them on a line with a bank of about 12 IR lights and it moved at approx. 4 feet a minute. Coat them and as they move throught the "chamber" they cured. The lights faced one another and then when the parts came into "view" the cure process started. As the part moved through the IR bank, they cured and then exited. Approx distance from part to light was 14 inches. He coated rings ALL DAY LONG in this fashion. Pallets full of lock down rings left the facility and his "IR oven" space was no wider than that which you would walk on and about 10' long, tucked up against the side of the wall. From blast to packaging, his whole entire coating area took up about the space of a common one car garge. THAT is making the most of your space! More importantly.... THAT is what IR lighting is all about...... a lot of heat concentrated in a tiny amount of area. In your instance.... the IR will be folded up and moved out of the way for precedence to use as a mechanical area I'd assume. To answer another question, yes.... the closer yo get, the warmer your temperature. Effective range is 12-16ish inches as stated above. A good general rule of thumb is 12"= 425 degrees, 14" = 375, 16" = 325 and if I were to use as a heat source (such as if I were working in a cold garage and had no alternative heat) I'd have them several feet away from me to keep me warm. Keep in mind, when using these lights for coating purposes..... these lights heat the metal as well and not just the powder coating. So if you have say.... we'll use my infamous widget example for this one, a piece of 36" X 36" by 1/2" thick aluminum widget..... the heat transferred from the operating side would most assuredly travel through to other parts of the widget and cure to some degree, beyond the "view" of the IR (backside or farther out on the piece as expected). ""I don't think I have ever used a IR light before. Can you bring me up to speed on how it works."" ..... sure you have. ever eat french fries from a fast food place? Your food was kept warm by a very weak version of that very same IR. They are not one and the same as far as coating and curing your powder go (that question was raised not all that long ago here) but the principal is the same. Those lights are of a "long wave" format. Think of big long gentle waves on a calm ocean.... not to much to speak up in ways of activity.... but the water is in fact, moving. Now.... think of a typical day of surf at the beach.... you can go in the water but there's no doubt water is moving at a good pace. This is medium wave. Now.... think of a bunch of power boats on a lake and the wake left behind them....now multiply the height of the wake by a little bit. Fast movement in bursts of wave..... but they always seem to lose value by the time they hit the shore (a great distance away)..... that is like short wave. Long wave travels farther... but not much "oomph" to really write home about, or in this case..... heat to get your part cured. This is why your french fries don't automatically get burnt as opposed to just stay warm. Medium wave is a typical day at the beach, so to speak. A good focus of waves and just enough concentration to get you wet and have fun to boogie board on for a while, but not forever. Lastly, we have the races on the lake. Fast and agressive.... water (or IR light in this case) moves rapidly and you'll most certainly perform acrobatic stunts if you jump over them with a pair of skis close enough. Will they make it to shore? Nope..... intensity that great never lasts for long and you have to be "in the sweet spot" to enjoy it, per se. Medium wave light is a good "all around" system to use. If you don't have a good amount of time to deal with the compact size of the M2000, get one M9000 and mate it along with one M2000 as stated earlier. The M9000 can be on the outside of the chassis while the 2000 can be directly opposite it inside catching what the bigger one doesn't "see" as a boost. If you are *just* redoing welds or small parts of some such... I'd suggest the S2000 due to the fact that it's like the power boat example.... but you are doing frames. Good for a valve cover maybe... but not for a large suface area such as yours. The goal is to mimic a large oven, after all. Personally.... if it were MY money, I'd get one M2000 and one M9000 just to cut down on the time factor and growth potential in the future. But that's just me. Hope that answered some of your questions...... Russ |
I can offer some insight as to building your own oven can be like. I have 2 of them myself, one is 4' deep 2'6" tall and about 2' wide. Two elements, basic house oven elements, and to answer whoevers question it was, YES you can wire them up so both are on at same time. If you look at the wiring for a house oven, you have a 3 or 4 wire system, 2 hots and 2 grounds (4 wire), 1 ground (3 wire). The two hot wires are both 110v a piece, they are combined in your oven controller to divy (sp?) the power to where it needs to go. The top element is 110v the bottom 240v. Wiring them up together so far has not been a prob, so far! lol There is also a fan mounted in this oven, now let me say something here. I am CHEAP!!! If someone else did something or made it, so can I! I will build it before I buy it, don't think making a 100kv adjustable Pc gun hasn't crossed my mind and drawings. There is the theory again, someone built it, so can I! Commonsense has kept me from shocking myself to death. Anyways, like Non-stick said, if you are really not going to need the big oven on a daily basis, it does take a lot of space and money and time to make one. I have another that is not quite complete yet, 8' tall 4x4 wide and deep. It has been a on going project, and it is HEAVY, about 1400 pounds right now. No wiring, no fans, no electronics in it yet. You need help building something like this, and the tools to do it with. I have every tool known to man and it takes time to do it right, and safely. I have a IR light, but for my usage it is not something I need to use to do my job, I am much to busy to not have a large oven to do my parts. But when I did this stuff for fun and just my own parts, it was great. I put it away when I was done, and my shop was much bigger. Now you walk into my shop wearing full armor, and still run into stuff and hurt yourself. So there are ups and downs. Also the fan need to be intrinsically safe, they cost $$$$$. There are ways around them, but as I said, they take time to make and some thought involved. Either way have fun.
looks like I need to find a suppplier to have a "make your own" oven type of kit already pre-fabbed. I'd make a fortune,lol.
also.... stop playing with the 100Kv powder supplies. I can tell you first hand they will knock you down if you get a zap! (we won't ask about that one,k? lol) Cheap is good.... as all can attest in here I'm the cheapest guy going. But safety ? Oh nooooo.... no, we don't skimp when it comes to safety one bit. My life has no price-tag on it. Keep that in mind no matter what you decide or do. |
I have never personally seen the material you mention being used in building an oven. But I do know there are more way than one to do the same thing. You are thinking the same way as I with the fan mounted internally and the motor externally, thus eliminating any direct contact with an exposed spark. One thing I have seen, the fan, shaft and motor should not be directly linked with each other. The shaft will carry heat into the motor and possibly damage it, whether or not this is true I don't know. Most industrial units look to be mounted directly, so your own commonsense be used with this. As for elements, if you have enough airflow, the oven should be even heat all the way through, as long as you diffuse it somehow to be blown where the cold, somewhat remote spots of the oven are located. I think that is just something you have to play with and see what works and what doesn't. Heat rises, so in theory the top should be the hottest, the bottom the coldest.
My smaller oven is just made out of 18 gauge sheetmetal, on a 1 1/2" angle iron frame, with 3/4" square tube making the frame for the oven itself. It has 3" insulation all around sandwiched between the inner oven walls, and the outer skin. All frame work was welded together. My larger oven is made of 4"x4" square tube, with 18 gauge panels, 4" thick walls. The reason for this monstrosity is I planned on moving it from the beginning, so I built it like a tank. My shop is just too small, and I plan on moving to a larger location for my work with PCing. Your idea on creating a multiple sized oven is a good idea, but you may run into some problems trying to circulate the air properly. Say your oven has 5 chambers, you have circulation running for a big piece using all five chambers. If you do a small piece and only need one chamber used, you airflow is going to be different. Maybe your rheostat idea may work, but I see you may be playing with that bit for a while to get it just right. Go for it, but make sure you really need it. Good luck P.S. ----- Non-Stick, as I said with the 100kv homemade gun, commonsense kicked in and I will buy one instead! lol And everyone, I must say non-stick is a huge help on this board for all involved with Pcing, Give him a hand!!!!! |
visible when moving onto the next section to be cured,bud. First section will be "melted" and have flow to it... then it will start to get grainy and half melted, and then gradually to "powder" status. Once you move the lamp to the grainy section, the process repeats.
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 03:43 PM |
| Question for all gas oven owners | getastro | Powder Coating Questions | 3 | 06-16-2005 11:35 AM |
| batch oven question for any electricians out there... | ray9i9 | Powder Coating Questions | 1 | 04-01-2005 12:41 AM |
| building a oven question | Jay87T | Oven Building Forum | 3 | 03-01-2004 05:28 PM |
| Oven question for the Gurus | jbento | Oven Building Forum | 1 | 05-16-2003 10:33 PM |
