Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Closed Thread
Old 04-18-2004, 09:54 AM
Blademan's Avatar
Blademan is on a distinguished road
Default wiring
Does anyone have a simple wiring diagram for hooking up a 220 element with thermostat?
Thanks
Old 04-18-2004, 09:24 PM
Do you want paralell or series system?
Old 04-19-2004, 07:36 AM
Blademan's Avatar
i'm supossing series , I want to connect two oven elements up in a 3x3x5
box...
thanks...
Old 04-20-2004, 01:55 AM
Do you want each element to see 220V?
I'll give you paralell because it's easier to add elements at any time.
However you go it's like this-- Thermostat or Temperature controller
is wired 110V and trips a relay that isolates
the 220V. The elements are wired white
and black to relay.White on one end and
black on the other.The neutral isn't used on
heating elements.The controller can get its
power from the neutral and one of the 220V
lines, either black or white.But not both!
For paralell you simply connect another
element to the first like jump starting a car.
White to white and black to black.
Wayne when I get a free second I'll draw it and email it to you.
Old 04-20-2004, 07:55 AM
Blademan's Avatar
Thanks dale!!!!!!!!!!!!!!!!!!!
Old 04-20-2004, 08:15 AM
Noob2PC's Avatar
Noob2PC
would Two elements be enough for an oven that big?
Old 04-20-2004, 11:00 AM
senna-the-great
Noob,
I built an oven a month or so back that is 3 by 4 by by 5 inside and
it's got 2 - 220 volt element's that are 3500 watt's each. The pre heat
take's a bit but I wanted to keep it under 30 amp. It has an industrial
temp control that would cost a mint except a buddy at work wired it up
with used part we had laying around.
Hope this help's,
Art
  #8 (permalink)
Old 04-20-2004, 11:16 AM
Noob2PC's Avatar
Noob2PC
Originally Posted by senna-the-great
Noob,
Hope this help's,
Art
What did you use to insulate the walls? I need to build a bigger oven so I can do Harley Frames since that is where the big $$$ are down here in Fl
  #9 (permalink)
Old 04-21-2004, 10:04 AM
Blademan's Avatar
I just used regular house insulation and removed the backing cover off of it.
  #10 (permalink)
Old 04-22-2004, 03:30 AM
Carcher7878
Send a message via AIM to Carcher7878 Send a message via Yahoo to Carcher7878
I am new at this, and I also do cycle frames here in ohio. In fact I have a guy giving me his Whole car to do as in the outside of the car! lol biggest project yet, But I want to build an oven. no sense in buying an oven for 5grand and not be big enough. Does anyone have plans on these? Im looking for something about 6ft high, 5ft width and 4ft deep. Any help would be great! also, how do ya guys control the temps? I need help. lol
Thanks guys
Archer
Closed Thread
Wiring Diagram for oven thexporter Oven Building Forum 1 05-07-2006 12:57 PM
Oven Wiring Noob2PC Powder Coating Questions 2 02-23-2005 02:34 PM
Wiring 101 :) hvac36 Powder Coating Questions 3 12-23-2004 04:58 PM
Wiring (GE Appliances) oven upncoming Powder Coating Questions 6 07-18-2004 07:45 PM
Powder coating oven suggestion (wiring) tomg552001 Oven Building Forum 1 04-22-2004 02:02 PM
