Old 09-23-2005, 11:33 AM
mcaswell's Avatar
Caswell Inc Founder
Default An Idea -building An Oven From Cement Board
Has anyone ever considered building an oven using the cement backer board for the sides of an oven?
I thought they could easily be joined together using those angle iron strips with holes in them (the ones folks use for shelving) and some nuts and bolts. By placing the strips on the outside edges of the panels, there would be a fairly tight seal. It would also be easy to make one sheet into a hinged door.
Silicone rubber could be used to caulk the edge joint. It will withstand the heat, but not a flame.
As for insulation, I would think that the aluminum foil backed foam sheets could be easily glued to the outside of the cement boards.
I prefer the idea of an electric oven element for the heat source.
Of course, these panels come in approx 4x5 feet sheets, so larger ovens could possibly be constructed.
A cement board baffle could be placed into the oven if a gas heat source were used.
What I like about this idea, as opposed to steel sheet, is that the concrete board actually absorbs and holds the heat, letting it radiate back into the oven when the door is opened. It should save energy.
Have A Web Site?
Old 09-23-2005, 01:39 PM
kchotboat
Default Re: An Idea -building An Oven From Cement Board
http://forum.caswellplating.com/show...3&page=2&pp=10
Go down to post #16.
Old 09-23-2005, 01:41 PM
kchotboat
I need to try it since we have cement board left over from tile work we did in the house.
Old 09-23-2005, 02:18 PM
pickleboy's Avatar
very good idea mike. i am looking to expand in the very near future to do long parts so i will most likely use this idea.
Old 09-23-2005, 04:06 PM
mildman61755
I think that the cement board would absorb alot of the heat, what about the reflectability(msp?) of the aluminum inside walls? Still think it is a good idea, but as a heat sink sandwiched in between insulation & a sheet metal inside. maybe I think too much. Comments most happily welcomed. Steve
Old 09-25-2005, 10:24 AM
I think the cement board would work well as it doesn't take on heat readily.
Most heat sinks are made from materials that take on (gain) and give off (loss) heat easily.
The advantage of the cement board is you'd have some thermal mass working for ya
IMHO
Old 09-26-2005, 01:48 AM
crazy_mtb_2002
I made the oven that was in the other topic, it works great, however i use a gas method of heating it, which is dangerous, but i have methods that protect the oven from ever combusting. i also used 2x4's to frame it all, since the cement board does heat up slightly, but not that bad, it's doesn't really affect the frame at all. It works great, and only cost me around $250 Canadian to make.
  #8 (permalink)
Old 09-27-2005, 10:05 AM
I would think that you could use furnace cement to seal it on the inside. It's very easy to work with and is capable of taking tremendous direct heat. I used high temp silicon to seal the inside of my oven and it worked great but I think you might be hard pressed to keep it on cement board.
  #9 (permalink)
Old 09-27-2005, 01:06 PM
boink is on a distinguished road
I am in the process of building one 6(h)x3x3. I am using steel framing as the support and reflective furnace board on the outside of the cement board.
By making it 6' tall it saves some floor space and its easier to get a motorcycle or atv frame in without handling it much. I am also incorporating a racking system inside as well as the ability to vary the interior dimensions of the oven. (for smaller batches)
I'll try to take some pics today...
  #10 (permalink)
Old 09-27-2005, 09:16 PM
crazy_mtb_2002
for caulking pick up a tube of 2000F fire place sealent, it works great, and gets the job done.
