Originally Posted by Njznumba1stunna
Thanks. Also I have 3 heating elements. Were can I buy a box or something to power all of them on and to have a thermostat with a temperature switch?
Find out what the wattage is for each of your elements. Add them all up for total wattage. Then take your total wattage and divide it by your voltage. That will give you your amperage. Then using that amperage add 20% and look for a wire gauge chart or talk to an electrical supply house for what gauge you need (ex: elements = 1000w each and supplied voltage is 240v then 1000w x 3 elements = 3000w and 3000w/240v = 12.5A, then 12.5A + 20% = 27.5A). Most of the time oven outlets should be wired using 8 gauge wire with a breaker thats only rated 10% above the calculated amperage. This trips the breaker without burning the house down first.
Then you can just add a 240v single phase tstat. My choice would be one like item# 47525K64 on mcmastercarr.com or if you have one, the controls from an old oven would be a lot better/cheaper.
Before the tstat thought, there should be a simple on/off switch that can handle the load. I have also though about staging the on/off switches (a switch for each element) in order to slow that initial in rush of electricity.
I haven't built my own yet but am hoping to in the near future. You're doing a good job on yours. keep posting pics and updating us
