  #11 (permalink)
Old 11-02-2005, 09:03 AM
Default Re: New Oven...
Jim, When you look at the insulation you might want to look at mineral wool. I used it in my oven and have run it up to 900f for about 15 mins and it worked great. When I bought my insulation it came in 24"X48" sheets, but the company I bought it from asked if I wanted it in a 4'X8' blanket. I believe you could get it as thick as 6". I used 3" thick 9lb rigid mineral wool. I know fiberglass will work but after researching the thermal properties of both I think in your particular case it might be best to use mineral wool. The extra heavy walls of your tank/oven will retain more heat for an extended period of time. Because mineral wool is so much more dense than fibeglass is it will outlast fiber and will retain heat much better. I also found that mineral wool isn't too much more costly than fiber glass. The price difference when I bought mine, for the same amount of thermal protection was only $7.00. BTW the high temp limit of the insulation I used is 1400f for no more than 2hrs, and it's fire resistant. I figured it might be worth a look for you as well.
  #12 (permalink)
Old 11-02-2005, 02:08 PM
KZjim's Avatar
KZjim is on a distinguished road
Send a message via Yahoo to KZjim
bzer1.. Thanks for the info.. i'll check it out. i want tp insulate as best as i can.. no sense trying to heat the whole state...LOL
If it jams; Force it. And if it breaks it needed replacing anyway.
I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
  #13 (permalink)
Old 11-02-2005, 02:45 PM
pickleboy's Avatar
bzer do you have a brand name to start us off with? i am planning a oven rebuild/extension on my big oven and need to reinsulate it complete.
  #14 (permalink)
Old 11-03-2005, 09:02 AM
I bought it from a company here in Jersey. They sell all kinds of industrial insulation. http://www.mcneilusa.com/. They were very helpful when I called them. I would suggest that you might want to poke around in your local area because I was told that they would only deliver locally. I found them by googling rock wool or mineral wool.
  #15 (permalink)
Old 11-03-2005, 12:36 PM
KZjim,
Our commercial oven (inside) is 51"h x 37"d x 25"w, it is 30amp 220v 6.5KW element which equals about 22,200 btuh. You really don't need much in the way of a circulation fan. Our has about a 5" diameter blade running about 750 rpm. If you mount a fan (and you should) make sure to get a second smaller blade. Something around 2" or so.. Mount it on motor shaft outside of the oven, it will act like a heat sling and keep the motor from frying. Holes in the bottom is a good idea Ours has about 15 1.5" diameter holes in the bottom under the element and a vent on the top. McMaster Carr is where we got our insulation.....
Probably more than you wanted to know
  #16 (permalink)
Old 11-03-2005, 09:03 PM
KZjim's Avatar
Popeye,
Thanks for the great info.. i have just the fan too!... Didnt consider the holes in the bottom.. but i will..
Which insulation did u yous from McMaster?
  #17 (permalink)
Old 11-04-2005, 10:10 AM
We used 9356K13
More than happy to help when I can
  #18 (permalink)
Old 11-04-2005, 03:19 PM
KZjim's Avatar
I like the idea of this fourm....
Ill check out the insulation... Gonna work on the bottom of the tank tomorrow... if i dont screw it up... ill have pics to post...LOL
  #19 (permalink)
Old 11-15-2005, 08:35 AM
KZjim's Avatar
OK.. for you that have wired your ovens already... i have designed my schematic for mine, take a look and see if i missed anyrhing... thanks
  #20 (permalink)
Old 11-15-2005, 09:33 AM
KZjim's Avatar
1 more try
http://i32.photobucket.com/albums/d3...venWiring1.jpg
Good oven shell for wanting to build your own oven dannydone Powder Coating Questions 6 03-21-2006 10:40 PM
