Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Closed Thread
Old 11-07-2005, 02:33 PM
myillwillinc's Avatar
myillwillinc
Default 2 or 3 wire question
if there are 3 physical wires coming out of the plug, why is it called a 2 wire setup?
Old 11-07-2005, 08:59 PM
speeddemonrodsteration's Avatar
Default Re: 2 or 3 wire question
they don't count the ground as a wire
Save the trees- burn Rubber!
Old 11-08-2005, 12:13 AM
pickleboy's Avatar
this was just explained to me the other day by my electrician buddy. the old way to wire 220 volt was with 3 wire cable that had 2 hot wires and a ground. today if you ask for 3 wire you will get 4 wire cable that has 2 hots a neutral and a ground. reason being before all the electronic controls on ovens and dryers the 3 wire was fine because the circuit had 2 hots and a ground. on the newer stuff that has clocks and such on them, the elements still have 2 even hots but the electronics draw some from only one side/ hot wire and then unbalances the circuit, this means you need the common neutral to rebalance the circuit so you dont get stray voltage to the case by way of the ground. so they came up with the 4 wire system to correct the problem. this has been the case in all countries except the US for about 5-7 years, and only in the US for about the past 2-3. hope this clears some of the confusion up.
Closed Thread
How do I wire up a 220 to my box? Hodges Oven Building Forum 3 10-25-2005 11:38 PM
How do I PC wire wheels that can't be taken apart wolfpline Powder Coating Questions 5 10-25-2005 04:40 PM
where to buy aluminum wire jtsuttle Anodizing Questions 1 03-21-2005 04:42 PM
Precision Wire Placement with a CDW Fibergeek Anodizing Questions 4 11-25-2004 11:07 PM
wire rims craigcraig Powder Coating Questions 3 07-03-2004 08:05 PM
