datadawg,
You are correct on the Duct Insulation "Ultra Gold". I lined the entire inside doors everything with this. Kind of expensive but works well. The ducting is 22ga I think, comes in 4'x10' sheets. Its expensive unless you know someone who owns a HVAC business and is willing to sell it to you at cost. I used steel studs to frame the unit, then lined the inside with the Ultra Gold, you will want to cover all metal on the walls and ceiling to prevent heat transfer through the studs. |
Datadawg,
Of course the heat source is totally up to you. But I prefer the control of Electric. This is where I purchased my elements. http://www.emeraldelectronic.com/sto...ID/46/file.htm |
Sorry to dig up an old thread but I like the way the elements are mounted in this oven (electrical boxes?). I am curious as to how you would insulate the wires inside the boxes, or would you have to use high temp. wire? I would really like to build mine this way if someone could explain this to me.
i think the boxes are used more for mounting than wiring. as a side note most elements that have wires attached will have the high temp silicone jacketed wires on them. if they are stud ended then try to get the connections outside of the hot zone if possible.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
Thanks Pickleboy. I realize the boxes are mainly for mounting the elements and I think I was unclear on what I want to know. Looking at this picture, even leaving the boxes off and mounting right into the top of the panel they are mounted to here, how would you insulate regular wire on the back side of the panel if the elements only have studs, because I'm sure heat would sink right through it.
http://forum.caswellplating.com/atta...4&d=1132365452 Sorry if my question doesn't make sense, it seems that I'm having trouble finding the right words. |
| LCD anodize of a large piece? | scocklin | Anodizing Questions | 2 | 12-29-2004 01:21 AM |
| Chroming large objects | Owen | Electroplating Questions | 2 | 12-12-2004 03:05 AM |
| large part finish? | slamed150 | Metal Polishing Questions | 4 | 07-11-2004 11:03 PM |
| Large Marine Project | geocash | Metal Polishing Questions | 1 | 08-21-2002 03:47 PM |
| large parts | rickcopeland | Electroplating Questions | 2 | 03-27-2002 01:53 PM |
