SIX!?!?!, Sheesh.. I'm looking for #3 and cant find any!!!..
Friend Boomtastic has 8 last I checked.. (miles away), You probably know him from .nl site.. Ended up here because I am going to build a PC oven and re-blast some parts so the poor convertible can go back together with a more durable finish on the suspension parts and other areas.., the water-based paint they used back 20 years ago just didnt hold-up send your email address to me at berkelusa@hotmail.com or post it here Rob
My site & DIY Groups:PABLASTER - Rob's Projects - Powder-Coating - Metal-Casting - Lathe Group - 1930's Chevys - Fiberglas' - CNC Tables - GOT LINKS??
Sorry to butt into the oven building stuff but do any of you Fiero guys know V8 Archie? Knew him well and worked with him when he was developing his V8 kit. Lost track of him when he moved from Michigan.
HobbyTalk Forums: Diecast Collecting - Model Building - Radio Control Vehicles - Slot Cars - Small Engine Repair |
Maybe you can answer this. How many heating element can be connected to one oven controller? |
?NONE ! The controler fires-off the relay and the relay powers the elements on the high-side. IE: 110-volt coil swithing on 220-volts to power the elements that are all wired in parallel on the relay... If the temp goes above the temp setting the controler shuts off the relay and they start to cool, when it goes below the temp (range) that is set the controler fires the relay back on again and the elements start to glow and the cycle starts all over again.. heating, cooling, heating, cooling... On a bread oven its a 5 to 10 -degree "range" before the controler kicks ON or OFF again.., But also consider that in a bread oven there is another element in a pan heating up water to create moisture so the bread is "proofed" Rob
| Powdercoat and Food??? | hoytheld | Powder Coating Questions | 5 | 09-01-2005 10:23 AM |
| 1st polish in 30 years, man I'm rusty | LeeParsons | Metal Polishing Questions | 4 | 08-24-2005 09:59 AM |
| Purchase of Gun and Equipment | swancott | Powder Coating Questions | 6 | 10-12-2004 02:45 PM |
| Equipment for sale | brassman53 | Services Offered/Wanted | 2 | 07-08-2004 12:15 AM |
| plating equipment | wallyaction | Electroplating Questions | 2 | 07-25-2002 12:45 PM |
