Old 11-23-2005, 10:33 PM
tavo1765 is an unknown quantity at this point
Default Problem with oven heating up
I have a Greunburg 8x4x6 electric oven, its a 4 wire (2positive leads/ground/nuetral) 230 volt oven thats requires at least 206 volts to operate correctly. The over is 76.0 amps, its on a 100amp breaker. In my shop there is about 1200amps service plus a 3 phase line if needed.
Tonight I ran into a problem with it getting up to temp. it was only getting up to about 170f in 30mins, usually it would be about 350f by that time. I verfied the fuses, and voltage getting to the oven which was 208vac. Anyone good with ovens have any ideas what could be the problem.
Old 11-23-2005, 11:49 PM
pickleboy's Avatar
Default Re: Problem with oven heating up
try disconnecting all the elements and ohm them out i would guess that is line voltage was equal and good then one of them might be burning out if you have 2 or more the should all read close to the same ohm rating. if not, if one reads real high it is most likely bad and then wont heat properly.
Old 11-24-2005, 12:05 AM
sswee's Avatar
Moderator
Just curious but you said you had a 3 phase line. Is it 240 or 480? If it's 240 3 phase why don't you wire your oven off the 3 phase line? You wouldn't have to keep worrying about overloading your main service and would probably drop you electric bill if it is like it is where I am at. I wired the home oven I am using now into a 240 3 phase box from where a lathe use to sit. SS
Oven problem !!!!! tavo1765 Oven Building Forum 4 10-23-2005 04:05 PM
Oven problem !!!!! tavo1765 Powder Coating Questions 7 10-06-2005 05:21 PM
Building oven and need some help with a problem... Nutster Powder Coating Questions 1 09-05-2005 07:42 AM
Custom oven material and heating element help needed DarinReiss Oven Building Forum 13 12-27-2003 09:24 PM
Heating Dyes SDE Anodizing Questions 3 09-02-2003 07:15 PM
