just something to keep in mind bro.my big oven is skinned inside with thin alum. panels and over the time that the las owner and myself have used it the alum panels will tend to gro and warp i will try to shoot pics this afternoon for you. not that it it a bad idea, just that you may need more studs to anchor to to keep the inner wals flat. by the way it looks great so far.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
Thanks for the heads up, I hope that doesn't happen. If it does, it will be pretty easy to drill the rivets out and put in something else, since nothing overlaps the interior panels. Yeah, I'd like to see a pic or two if you get a chance.
Maybe I'd better add a couple of studs as stiffeners. |
You might want to consider using button head rivets to attach the liner panels. You could drill .25" holes in the liner and .125" in the studs, that would give it some breathing room to expand and contract without warping as much...
AND, if you ceramic coated the liner panels it would reflect the heat instead of sucking it up.... Just a couple suggestions, so don't take it personal |
How do you drive Button Head rivets? Interesting idea about the Ceramic coating.
The heating elements arrived today. I think I'll mount them to the bottom before the side sheets are put on. Pics to follow. McMaster Carr has a great selection of elements. I'm starting with two 1500 watt bendable elements. |
Button head rivets are installed with a standard rivet gun. They just have a button head as opposed to a countersunk rivet. Most speed shops carry the large button heads for panel replacement on race cars. SS
I heated up a side panel today with the kerosene heater. First, I had no idea that these things put out so much water vapor. It was impressive to see it condense on the aluminum panels.
After I heated the panel quite a bit, it bowed in the center due to expansion. I think some of you predicted that. Popeye: I took your advice and drilled out the side and bottom panels, drilled oversized holes in the panels and used steel pulled-rivets with big heads (about 1/2 inch diameter). Luckily I have a pneumatic gun for Cherry rivets, these things were hard to pull with the hand tool but the Cherry gun works great. Bottom line: The combination of large hole, large rivet head area and the fiberglass tape underneath made a perfect seal, but still allow movement to take up the expansion. Thanks for the help, guys. Tomorrow I install the heating elements. Steve |
| Oven Metal | 04sp500 | Oven Building Forum | 11 | 03-25-2006 10:25 AM |
| New Thread: Bought Cement Board N Studs :Pics: | Njznumba1stunna | Oven Building Forum | 35 | 11-03-2005 12:48 PM |
| Annodizing aluminum auto a/c metal lines | acsource | Anodizing Questions | 1 | 11-24-2003 11:49 PM |
| Oven metal | 04sp500 | Powder Coating Questions | 4 | 07-10-2003 09:15 AM |
| pot metal or aluminum | neil | Plating Pot Metal | 2 | 07-07-2003 11:52 AM |
