I am having problems with my new oven. It will only heat up to 350 degrees after an hour. It has concrete board inner liner and two 3100 watt elements and a fan. I'm thinking the concrete board is the problem. How can I get it up to 450 degrees? Any idea's welcome. |
Yes, it is a homemade oven. Inside dimension is 24 wide by 48 length and
36 high. Panels are sealed with silicone. Window on front is double pane. Voltage is getting 220v. Elements are turning cherry red. Do you think that the concrete panels are drawing all the heat up? Last edited by mcaswell; 12-06-2005 at 10:30 PM. |
When you say concrete panels, do you mean like 1/2" cement board or something different?
Do you have any kind of vent in it for air expansion? It shouldn't be anything to hard to fix. As many guys here running home made ovens, someone has hit this problem before. SS |
The oven looks good. Sounds like everything is up to snuff. The cement board shouldn't be absorbing enough heat to cause problems. By the description of it, it still sounds like a low voltage problem. A 220 circuit needs a minimum of 208V to function properly. Someone not to long ago had the same problem and it was due to his power line only having 206V. SS
I agree with Sswee, check the volt/amps first and go from there..
You might want to consider putting a piece of metal behind the element to help reflect the heat out. Try and keep a small air gap between the metal and cement board too. Air vent should be bigger.. IMHO |
