Sorry I should have started my own new post but I posted in this thread instead. ( An Idea -building An Oven From Cement Board )
The oven is 6x4x3 and is constructed of steel studs and durock. Heat is supplied by a 175k-350k LP Forced air unit. Now to my question('s), Do I need a vent of some sort on this unit? I wanted to use Electric elements but I know nothing about electrical wiring, amp, voltage etc. I may use "loosely knitted" rope for a really snug seal, is fiberglass an acceptable form of material? http://www.mcmaster.com , rope seal , 8818K45 I'm stressing because, after all it is PROPANE..!! ANY info would be great, Thanks a lot. |
"I'm stressing because, after all it is PROPANE" as for the worries on propane i think it should be safe as long as you are very careful with the bottle placement. propane generally burns about 90-98% clean, so fume problems should be minimal. hope this helps some bro.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
Thanks a lot.
I'm not even getting close!! I need another 100 degrees and it just isn't happening, this is so aggrevating. I believe there is to much airflow kicking back to the heater and the flame is going over the back side of the heater and that is when it cuts/turns off. I have no clue what a solid baffle or a damper is but I will goggle it and hope to find some info out. I read in other threads where people talked about the dampers but Im just not familar with them. I'm so frustrated its unreal.. I will go to electric if I cant get this propane to work, I just really needed to get the frame done before christmas. Thanks for the reply |
damper would be a tube with a disc in it that will open to full flow or close all the way across the tube to close it. like a butterfly valve if you are familar with them. or similar to a fireplace chimney flue. as for solid baffles you may need to build some sort of plates alternating diagonoly from left to right then right to left in kind of a stairstep stagger. this will slow down the flow of air to the box but should stop most of the backpressure to the heater. if all else fails cut a small v notch in the end of the extension pipe from the heater to the box. this will allow some of the airflow to escape and also relieve backpressure. if i could draw on here i would since my explaining is not the best. if you are getting backpressure on the discharge end of that heater it will cause an overtemp and shutdown. if you need help shoot me a pm and i will give you my phone # so you can call.
The air that the heater puts out is pressurizing you oven and backpressuring into the heater causing the thermal overheat switch to shut down the heater. That type of heater has the switch as a safety feature to keep from burning the heater up.
A damper in that respect is going to be a hole probably equal in size to the inlet but located in the top of the opposite side and will have a piece that can be rotated to cover the vent hole in any amount desired. Dampers are commonly used on BBQ pit stacks as a plate that rotates over the top of the smoke stack or fireplaces as a disc inside the smoke pipe that can be rotated to restrict or dampen the heat flow out of the pipe. I understand your hesitance in delving into the electrical way if your not familiar with it but due to the safety issues, you aren't going to get the assistance as you will going electric. I hope you understand. SS |
Thanks guys, Well I just done removing 2 of the 4 blades on the heater fan to try and slow the air flow, needless to say the backpressure is still there...
The damper idea must work but just seems like it would let to much heat out ![]() (trust me I understand you can/do meter the flow out.) As far as the homemade baffles your speaking of I'm a bit lost so will take you up on you phone call offer, pm on its way. Thanks fellas. |
Either buy a Gas oven from a company that makes them for this use or Build and electric oven please.. Need help wiring it I will be more then happy to talk you thru it or draw you and image or snap a Image of mine... Lets be safe folks... Jim S....
Jim Shuster www.backyardpowdercoating.com Sold..... www.chrissys68mustang.com Hobbie www.photogserver.net Web Hosting. |
I should be able to get a pretty penny for this heater that should cover any expense all the electronics will cost. What about Radiant heaters?? Thanks again |
| Oven venting? | viper56 | Powder Coating Questions | 2 | 12-05-2004 10:54 PM |
| venting? | csaddler | Oven Building Forum | 4 | 01-20-2004 11:03 AM |
