Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Closed Thread
Old 12-17-2005, 05:46 AM
remotestartdepot
Default Where to get insulation?
I know a lot of you are using that foil backed foam board, but the local Home Depot don't seem to carry that stuff. Where is the best place to find that stuff and what should I expect to pay? Also, is there anything else that I can use for insulation? Will good ole Pink Panther fiberglass insulation work, or will it burst into flames.
Thanks for the helo in advance!
Kris
Old 12-17-2005, 01:56 PM
cdaeme's Avatar
cdaeme is an unknown quantity at this point
Send a message via AIM to cdaeme Send a message via Yahoo to cdaeme
Default Re: Where to get insulation?
If you live in or arround a moderate size city check the Yellow pages for insulation suppliers. I called around yesterday found a local supply house that carries Mineral Wool (aka Rock Wool) for $2.49 for a 2'X4'X1 1/2" sheet.
While talking to the salesman on the phone he asked what I was using it for the discussion then changed to powder coating. He wants me to look at coating some Jr. Dragster parts while he is doing his winter rebuild.
Jason Williams
Auto-Cycle PC
Chattanooga, TN
Old 12-20-2005, 01:17 AM
gourdhedd's Avatar
gourdhedd
I used a 2" thick, 3 PCF unfaced fiberglass board for my oven. The same product is manufactured by Owens-Corning, Knauf, Johns-Manville, and Certainteed. Do a google search to find their websites and then look for a "Where to buy" page. This should lead you to a local distributor. You can also do a google search for "General Insulation" to find out if they have a warehouse close to you.
I paid about $66 for an 80SF bundle.
Gary
Gary Brady
www.powdercoatoven.4t.com
Old 12-22-2005, 12:04 PM
kd5sfq is on a distinguished road
Call me cheap but mine came from Home Depot. I used R-13 wall insulation and removed the plastic wrap. The fiberglass has a melting point of 1,000 degrees F. So it's okay to use. Domestic ovens use the same type of insulation.
Old 12-22-2005, 05:18 PM
sdold's Avatar
sdold is on a distinguished road
Same here, I bought the stuff with kraft paper, and just peeled the paper off. It seems to work well in initial tests.
Old 12-31-2005, 08:11 PM
KZjim's Avatar
KZjim is on a distinguished road
Send a message via Yahoo to KZjim
try McMaster/Carr they have 1000deg blankets that are 3/4" thick
If it jams; Force it. And if it breaks it needed replacing anyway.
I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
Old 01-06-2006, 03:07 PM
sab0276 is on a distinguished road
Are you talking about the Dow Tuff-R R13 Insulation at Home Depot.
Any problems? Melting/burning/smoking?
-Scott
  #8 (permalink)
Old 01-06-2006, 06:53 PM
Heavykote
I hit a Home Depot today and picked up water heater insulation. I am gonna take some plywood and wrap the insulation which is double foil backed and use some kind of adhesive to apply. Then, I can connect the pieces for my oven extension. It should work, right?
  #9 (permalink)
Old 01-12-2006, 05:17 PM
DJuanHouston is on a distinguished road
-Scott
I wondered the same thing cause the msds says 190F but i bet thats just because of the coating they pealed off
  #10 (permalink)
Old 02-13-2006, 01:46 PM
edwardpic's Avatar
edwardpic is an unknown quantity at this point
you can get mineral wool which is used in furnaces from McMaster-Carr. We just built a 4X4X6 oven using 2" of 1800 degree insulation---cool to the touch on the outside when running at 400 degress
Ed
Have pics of ove email me and i will send, can also provide part numbers of all the items used in our oven!!
Closed Thread
insulation and torpedo heater ? bryceballard Powder Coating Questions 1 06-26-2005 11:40 PM
Roofing insulation oven? knightda8 Powder Coating Questions 1 02-07-2005 10:48 AM
Rigid Board Insulation for Oven Construction?? trsick Powder Coating Questions 3 11-17-2004 10:57 AM
Totally off topic question about Insulation tomg552001 Other Metal Finishing Questions 22 12-26-2003 03:16 PM
