If you dont know what a Babbington is then read on...
Patent 3,425,058 - Robert S. Babington, Inventor "The Army tried for a long time to get this to work, but when the Marine Corps took the lead on the program, they discovered a new piece of technology called the Babington Airtronic Burner." Conventional high-powered burners shoot air and fuel through a nozzle, which gets clogged. This burner uses the principle of the whale. when a whale sprays a plume of water, it is not spitting water, but air. There is a thin film of water that forms over the hole and when the air blows out, it atomizes the water, making it look like a spray. The Babington uses the same principle, It is a sphere with a little hole in it. Fuel runs over the top of the sphere and air is pushed through the hole. When fuel flows over the hole it is atomized and sprayed into the chamber for complete combustion. This technology enables the burner to achieve a temperature of 2,000 degrees Fahrenheit. But because the burner produces such high heat, there are no emissions. FYI: I found a few pics online and will attach them..., But just looking at this thing it burns everything from cooking oil to waste oil in automobile engines... also read that even if it has a 20% water in the fuel that it will still burn and eventually vaporize all of the water with the extreme heat it creates.. Would LOVE to see if anyone has a waste-oil fires PC oven and how they went about doing it IF there is anyone here ![]() Rob
My site & DIY Groups:PABLASTER - Rob's Projects - Powder-Coating - Metal-Casting - Lathe Group - 1930's Chevys - Fiberglas' - CNC Tables - GOT LINKS??
Heat exchanger as in a pipe in a pipe with say the inner one being stainless steel and between the layers is where the heat generated is removed?
Couldnt you do that with the babbington and add a fan system to circulate the heat made between these layers?, Maybe a strong fan at one end and a screen at the other.. The output I would think is incredible and the fuel saving would make the thing pay for itself once built.. In the above pics the guy built one with a 2' or 3' black iron pipe, But what if this spanned the width of your oven at the bottom from one side to the other with the double layer pipe and fan setup.. Just my mind grinding again.. ignore the "whirring" noise... lol Rob
Added a picture of the babington ball. - Controlling the flame is as simple as shutting off the pump that pours the oil over the ball itself..., Connect that setup to a thermostat and your ready to ROCK...
Rob there is a yahoo group search for "alternate feuls" tons of info on this subject. Did you check out the magic heat? it is a metal box with 10-20 round tubes welded horizontally in the box. The heat from the stove pipe travels vertically around the tubes and heats them the blower is mounted in the back and blows through the tubes. This could work the way you refered to make a long 6" stainless pipe then drill and weld several 1" tubes across it. Then contain the force of the blower blowing over an through the tubes into the oven. The exaust the exits already cooled through an outside vent pipe like a hot water heater vent.
Jason |
Ahh I remember that.. yes.. seen one!
Bet it could be layed flat and used the same way IN an oven ya think?? So many ideas and ways you can go.. So little time.. lol Hey I have a ? on PC, But I'll start another post for it..
Check out the Beckett burners. They are a fuel oil burner converted to waste oil. They already have have the ignitor, pumps and safety devices needed. Works on the same principle as a babington only uses a tube instead of a ball. For $100-200 you should be able to build one of these to heat a PC oven.
Jason |
Had one in my hands today at the Junkyard.. Poor thing was ran over by the forklift tho... UGHH!!, But I will keep my eyes open.. (I answer the phone there sometimes and see everything that comes in..)
Got this yesterday for the Fiero convertible project.., The complete roof area from a convert Sunbird.. and only a day later the header is almost installed.. (in this pic its just the header part of the roof sitting on the top of my windshield for a test-fit after just getting home) I want to get the convertibles framework all done then powdercoat the parts in silver/black VIEN aka "hammered" just before the upholstery is made because they will be partially visible from sitting inside the car... I know.. WHO in GODS NAME wants a Fiero convertible?? Rob
| Heat oven using a waste oil burner??? | cdaeme | Oven Building Forum | 0 | 11-23-2005 10:23 PM |
| Powder Coat caught on fire! | Sleepr_Tech | Powder Coating Questions | 3 | 09-10-2004 06:22 AM |
| Waste | modifyit15 | Electroplating Questions | 2 | 02-01-2004 12:25 AM |
| Plating for a Fire Place | Sunshine | Other Metal Finishing Questions | 3 | 11-21-2002 11:18 PM |
| Waste Disposal | studuff | Electroplating Questions | 1 | 01-24-2002 08:53 AM |
