Old 12-20-2005, 10:28 PM
shemp4 is on a distinguished road
Default question on heating
hi, another new guy here!! i recently started doing some powder coating and i would like to build a large oven. (went from toaster oven to kitchen oven) i am getting alot of great ideas on this forum!! but i am trying to decide to either go with the electric elements or the torpedo heater. my question is how do you control the temperature with the torpedo type heaters? is there a thermostat that will control it to a specific temp? other than low,med,high and if i build my box how do you attach ? and what about a deflector ? dont these things blow kinda hard? thanks in advance. joe
Old 12-21-2005, 08:39 AM
Default Re: question on heating
Go electric, safer
Old 12-21-2005, 03:29 PM
sdold's Avatar
sdold is on a distinguished road
Those heaters put out a lot of water vapor, I don't know if that will effect the coating, but it's there. Also I'm be wondering about carbon monoxide with those things.
It's been a long time since I've taken chemistry, but as I recall you are fine as long as there is enough oxygen to combine with all of the carbon atoms making CO2, if there isn't enough oxygen, CO results (incomplete combustion). This is why it's important to have ventilation when using these heaters.
Restricting the oxygen flow through the heater by piping it into a box seems like it would cause this to happen. It would be interesting to try it with a CO detector.
infrared heating lamps jayc531 Oven Building Forum 2 12-01-2005 05:45 PM
Problem with oven heating up tavo1765 Oven Building Forum 2 11-24-2005 12:05 AM
out gasssing and pre heating? randygrapes218 Powder Coating Questions 2 06-26-2004 04:54 PM
Heating Dyes SDE Anodizing Questions 3 09-02-2003 07:15 PM
Tank Heating Questions. meganine Anodizing Questions 1 08-03-2003 03:20 PM
