Old 12-23-2005, 02:30 PM
volkaholic
Default recirulation fan for powdercoat oven
I've been powdercoating for about 2 years now using a normal kitchen type oven in my shop. I'm ready to build a bigger unit to handle motorcycle frames. I'm planning on going 32" X 32" X 60" tall, so I can hang the frames easy. Because it will be so tall, recirculation of the air will be important. I plan to take heated air from the top & duct it back down to near the bottom. I have been checking out this forum & have not seen too much about fan.
I need a fan that can handle the high temps (550 deg F max) for extended periods of time & a gentle air flow (low cfm) so it doesn't blow dust around or blow the powder off the parts.
Any suggestions on fan type, brands, vendors, salvage parts, etc? Relative costs?
Old 12-27-2005, 03:50 PM
Default Re: recirulation fan for powdercoat oven
That's pretty close to our oven size. We added a small fan at the bottom and it works very well. Many monies for a high temp blower!!
You should be able to mount a small motor on the outside of the oven and run the shaft through the sidewall and mount a small blade 5 or 6". We installed two smaller blades on the fan shaft on the outside of the oven as a heat sling.
Total we spent about $50
Old 02-13-2006, 01:55 PM
edwardpic's Avatar
edwardpic is an unknown quantity at this point
we used a draft inducing fan from Grainger, pulls the hot air that rises from the top center, ducted down the back wall and diffused with a panel on the bottom inside, works great-moves the air but doesnt blow powder off...we speant about $79 on the blower and its made for furnaces so can handle the heat.
Ed
Old 02-22-2006, 10:03 PM
wrascal is on a distinguished road
Have you ever looked at the blowers that are used in "air tight wood stoves".......... they are designed to move lots of air, have variable speed and have no problem with heat like that.
Russ
Old 02-24-2006, 12:42 PM
edwardpic's Avatar
BLOWER,INDUCED DRAFT
Induced Draft Blower, Metal Housing, 0.6 Amp Shaded Pole Motor Grainger Item # 4MH09
Your Price (ea.) $58.75
Brand FASCO
Mfr. Model # 70022771
Ship Qty. 1
Sell Qty. (Will-Call) 1
Ship Weight (lbs.) 6.15
Usually Ships Today
Catalog Page No. 3774
hope that helps---Ed
Old 02-24-2006, 06:40 PM
Timmer is on a distinguished road
ED...Do you have a pic of that bad boy installed?
Old 02-25-2006, 09:17 AM
edwardpic's Avatar
Yes, from the inside with the diffusers, you will have to email me, the pictures are too large to post here. I can take a picture from the top next week showing the mounting.
Ed
  #8 (permalink)
Old 03-18-2006, 11:05 PM
datadawg's Avatar
datadawg is on a distinguished road
edwardpic, can you email a couple of the pics of your blower setup? I am starting the framing of my oven tomorrow and want to make sure i set the fan up correctly.
Thanks
  #9 (permalink)
Old 03-22-2006, 07:34 PM
cordcutter is on a distinguished road
edwardpic, If you email the pics of your set up on how you ran your fan and air duct I can put them on my photobucket account and post them on here for all to see or post the link for people to see. I would also like to see how you did it.
Thanks
How big can I powdercoat? Having trouble gtabadboy Powder Coating Questions 6 09-19-2005 01:02 AM
Powdercoat and Food??? hoytheld Powder Coating Questions 5 09-01-2005 09:23 AM
I NEED HELP - Removing powdercoat freiwaa Powder Coating Questions 12 08-23-2004 09:34 PM
Can you powdercoat over powdercoat? gopedhead Powder Coating Questions 1 12-14-2003 05:17 PM
powdercoat pricing turch Powder Coating Questions 17 08-04-2003 10:48 AM
