IF ANYONE HAS ANY QUESTIONS ON HOW TO BUILD THIS OR WOULD LIKE ONE BUILT, EMAIL ME AT HVAC60441@SBCGLOBAL.NET. I AM A SHEETMETAL WORKER, ME AND A GOOD FRIEND DESIGNED THIS ONE IT TAKES 20 MINS TO HEAT UP TO 375 AND THE PART IS HEAT SOAKED IN THE SAME AMOUNT OF TIME AND THEN THE CURING TIME SO AVERAGE RUN TIME IS ABOUT 45 MINS. ELEMENTS CYCLE ON AND OFF ABOUT 5 ON AND 3 OFF SO YOUR POCKET ISNT HURT TO BAD. THIS RUNS ON A 40 AMP BREAKER AND HAS A SPEED CONTROL ON THE BLOWER MOTOR FOR BETTER FLOW.
great idea sdold. if jim would be willing to do a walk through it would be very benefitial(?).
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
I Used 22 Gauge Metal In The Interior And 24 On Exterior. The Blower Is A Double Shafted Motor With 2 Blowers Which Blow Air In And Down Thru The Duct And Out The Holes In The Wall. The Return Comes From The Bottom Across The Elements. I Have Found Pulling Air From The Bottom Instead Of The Top Works Better To Keep A Even Temp. I Used Unistrut To Build A Rack Inside And You Can Slide The Hanger To Any Height. I Also Used Bolt Hangers For Larger Heavier Items. It Took About 20 Hours To Build This From Scratch, And About 300 Hours Of Research
I don't see any insulation? Any reason for that?
| need to build fluidized bed | sagoland | Powder Coating Questions | 3 | 04-07-2005 05:27 PM |
| i want to build an oven | suprtong | Powder Coating Questions | 4 | 03-11-2005 01:43 AM |
| compound build up | chrisk | Metal Polishing Questions | 5 | 07-11-2004 12:32 PM |
| Plate Build Up | crawfish96 | Other Metal Finishing Questions | 1 | 02-15-2004 05:20 AM |
| How to build an oven | Sezer | Oven Building Forum | 2 | 12-24-2003 03:42 PM |
