Re: What should I use to heat
Finally, I found some people sharing ideas for ovens!! Thought this idea might help someone. I have built a few ovens over the past 20 years for molding plexiglass. The requirements are almost identical to those for powder, and I now use my plexi oven also for curing powder!
The best system ( I have a few in the scrap pile), is built with metal 2x4's from home depot and standard pink fiberglas insulation. It is about 6' x 6' x 4' high. The most critical problem I found is interior air/heat circulation. The cure, no pun intended, is big volume so the air has room to move, and a powerful fan. The system that worked best is this... I got an electric forced air home furnace from the scrap yard, and disected it, installed the heating element set and the squirrel cage fan inside the oven. I made an extended shaft for the fan so the motor stayed outside the oven heat area. Lots of heat, 10 min. to get to 400*F, and even temp throughout. I built an angle iron frame around and over the oven with a cable, pulley, and counterweight system so that the oven box raises 4' up off its floor to open. That way I can preheat, shut the power off, raise the box without loosing all the heat since the hot air raises with it, load the parts and lower the box, then turn the power on for the cure cycle.
You still have to be CAREFUL, getting hit in the face with a blast of 400* is very dangerous.
Another idea... I saw some talk about how to bend sheet metal for panels if you don't have a break. I did experiments years ago for my customers to solve this delema and came up with a solution that works well. Get a length of 2" angle iron a little longer than the longest bend you need. Lay it on the floor with the corner pointing up, like an upside down "V". Lay the sheet metal over the angle and line up the bend line with the angle ridge. Hit progressively along the line with a rubber hammer. Clamp the ends or have friends stand on them to stop them from moving when hammering. You will be surprised how close you can get to 90* and you can finish the bend by hand once the crease is there.
I now am going to build a 8'x 8' x 24' gas oven, anyone out there with ideas?
I have a machinery shipping container I will insulate for the box. I have found lots of info on building gas burners on the metal casting and blacksmith forums, not rocket science and controls can be found. My uneducated opinion is that a gas flame behind a metal panel shouldn't be more dangerous than a red hot element. Don't think an electric element is without risc if not used with care, I have seen fuel vapor egnited by a 12" long piece of red hot steel, Keep powder dust out of your oven!
Sorry for rambeling!!
