I have a natural gas line in my shop that I use to run the heater. Is it possible to use a gas over or build an oven with gas burners. Currently, I am using a toaster oven for the little stuff and a old electric oven hooked up to my welder circuit.
I would like to save a few bucks on my energy bill but not at the cost of blowing myself up! thanks |
I talked to an engineer at a local manufacturer that has an automatic powder coating line. They use a gas oven. He said there were three things to look out for when designing a gas oven for powder coating.
1. Put a variable speed blower in either the fresh air input or the exhaust vent to insure enough air flow and allow purging the oven when needed. 2. Use several small burner rather then one larger burner. This gives you better temperature control. 3. Use a three skin design rather than a two skin design. Use an insulation layer sandwiched between the two outside skins as with an electric oven. Then put a third skin inside to separate the firebox from the curing chamber. The firebox is really just a space on the bottom of the oven big enough for the burners that extends up both sides of the oven. The the floor of the curing chamber should be solid to prevent powder from falling directly onto the burners. The sides of the curing chamber can have vents to allow direct exchange between the firebox and curing chamber with out danger of powder falling back onto the burner. Dave |
my 8x8x13 is gas. well kinda. I have (4) 75,000 BTU heaters under it.
http://www.grainger.com/Grainger/wwg...mId=1612528977 They are Naural Gas and NO open flame to worry about. This oven has been up and running for 10-15 years. NO problems at all. Use to use it for heat treating aluminum bumpers. Now used for powdercoating. Heres a diagram of the electronics. http://www.cecoatings.com/images/Equipment/diagram1.jpg This is the oven http://www.cecoatings.com/images/Equ...enandbooth.jpg Its on a 1ft I beam. and the burners are under it. they its stitch welded on that. I can take more pic's if needed. Im also in the middle of building one more oven 6x6x8 Im using (1) 100,000 BTU heater in this one. http://www.grainger.com/Grainger/wwg...mId=1612528989 this one uses more ifficient mineral wool. so should be better. Same kind of electronics, just a smaller oven. I'm resizing and uploading new oven pic's later. |
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 03:43 PM |
| Oven problem !!!!! | tavo1765 | Powder Coating Questions | 7 | 10-06-2005 05:21 PM |
| Newbie and oven temperature ? | Netnut | Powder Coating Questions | 2 | 05-26-2005 09:49 PM |
| Gas fired pizza oven for curing? | BlindUmpire | Oven Building Forum | 4 | 02-27-2004 11:21 PM |
