Okay so I think that I am going to start ordering all the stuff that I need to build my 2'x3'x6' electric oven. Before ordering everything I am going to post it all up here and if you pc'ers could give it a look (I know Mike will, thanks) and give me any feed back that would be great. And there is a McMaster-Carr retail store nearby me so as long as I call ahead by a few hours I can just go and pick it up.
Im getting my insulation, heating elements (going with 4 1500W finned heating strips), and door seals from http://www.mcmaster.com/ part numbers, 3575K561 , 8813K31 , 9328K43 Thermostat, thermocouple, and contactor from Ebay http://cgi.ebay.com/ws/eBayISAPI.dll..._BIN_Stores_IT I already have all the metal to build it with and the rest of the misc. items will be purchased locally. Any advice would be great I don't want to order all of this and find out it wont work. Thanks a ton, Trey |
I don't know if this is at your house, or a commercial building..??
How many wires are coming into your service..?? single phase = 2 hot 1 neutral = 3 total three phase = 3 hot 1 neutral = 4 total Hots should be insulated neutral will be bare. |
if his house is fairly new it could have 4 wires on 220 single phase as well, being 2 hot 1 neutral and a ground.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
If who ever installed it told you it was 220 volt it's single phase but none of this really matters if for some reason you have a three phase entrance the voltage will be 208. Ac volts are Ac volts @220 you will draw 27.28 amps or @ 208 you will draw 28.85 amps in your case it dos'nt mater your using the voltage for resistance. I think double pole three phase is 208v then theres always the crazy leg. Don't worry about it either way your good. The higher the volts the less amps. Get the phase thing out of your head dude. It's all good. Now that I read over this it really dos'nt matter. As long as it's a 50amp outlet your good.
Okay I know that I have been gone for a while but I have finally gotten around to ordering everything for my oven. It is gonna be approximitly 2'x3'x6' using Mineral wool for insulation and the thermostat and contactor from ebay for controls. I got four elements at 2400/1800 watts per 240/208V from a site at only $6.71 a piece brand new. I already have the sheet metal and I came up with a really cool way toi construct my oven. You'll have to wait to see that though I am planning on taking pics and making another little up to date diy page on oven building. I already have the elements, thermostat, contactor, misc. wiring, insulation, and door seals ordered and in the mail. Im getting really close now.
And a cool little thing I found on www.mcmaster.com part #8209K17 it is ultra High-temp 14 gauge wire that will withstand up to 842F |
The 14 gauge wire is good for 15 amp thats cool if you wire each element stright to the contactor. Each element is going to draw 10 amps at 2400w at 240v. So get enough wire to make two runs to each element total of eight runs. Unless you get 10 gauge and split the elements two and two. Was I saposed to call you I can't remember I was saposed to call someone if I was I'm sorry e-mail me your number again if it was you.
| Final Scratches from buffing wheel | regulator | Metal Polishing Questions | 2 | 01-06-2005 11:03 PM |
| Shopping List | buzzurd | Metal Polishing Questions | 0 | 01-10-2004 05:32 PM |
| blue or green compound for final polish? | shine | Metal Polishing Questions | 1 | 07-26-2003 04:29 PM |
| Final finish on factory chrome... | mattgar | Metal Polishing Questions | 2 | 02-14-2003 09:47 AM |
| Electroforming/plating no metalic materials... | Toma | Electroplating Questions | 1 | 01-04-2002 12:53 PM |
