sorry for the misunderstanding. the way to do 2 colors will vary from person to person. if you are wanting to shoot 2 separate colors on the same piece and need a tape line then mask the part with with temp tape and shoot first coat. put in oven till full cure. remove and let cool. remove tape and mask other side and shoot second color and repeat above process. if shooting one color over another such as transparent or candy colors. then i shoot the chrome or white base and full cure them. then i remove the part from the oven and shoot right away while still at full temp. this will let the powder melt on contact and you can see the coverage. but be careful this way can cause you to coat to heavy in spots and have runs or sags. hope this helps
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
I just got done doing a fade on my quad frame. I faded from orange to yellow to match the flame graphics on my plastic. What i did was spray the orange, baked for 10 minutes, pulled it out and then sprayed the yellow. It turned out great, heres a picture.
