  #11 (permalink)
Old 11-20-2006, 07:22 AM
Hobweld is on a distinguished road
Default Re: Another Fridge/retrofit
I kept both elements low since heat rises. I have since added the fan through the top providing a upward draw and circulates down the sides. Like a ceiling fan
in winter. As for the wiring I just kept pretty much every thing that was there in the original stove. Adding the second broil element to the same circuit as the standard element by piggy backing it off the same wires. The wiring for the stove top elements was not needed so I opened the control compartment and removed the wires from there. This helped to clean things up a bit. The added fan was wired off the light switch so when you turn the light on they both run. It has been working great so far. And sure produces a nice product.
Ken
P.S. Yes you can run it just as wired if you wish. By me adding the broil element to the same circuit as the bake element didn't really change anything since the self cleaning model has the thermostat rated for both elements on at once. As during a normal cleaning cycle. Feel free to ask any question I can help you out with.
  #12 (permalink)
Old 11-25-2006, 01:11 PM
precise is on a distinguished road
I was checking your oven out and was wondering a couple of questions with it, How did you get the plastic lining out of the refrigertor, did you cut it out or pry it out Going to plan on making one like this so need a little help please
Troy J
whitehouse, tx
www.precisepowder.com
  #13 (permalink)
Old 11-26-2006, 12:48 AM
Hacked it out with a screwdriver. Once you crack it you can grab it and rip it out. The foam insulation under it isn't fireproof so it has to go. That took a lot of time. I used a air chisel with a flat blade welded to it to do that. Wear proper respiration mask as you don't want to be breathing that ****. It also gets into everything.
Have fun.
Ken
  #14 (permalink)
Old 11-28-2006, 10:34 PM
Thanks for the heads up
  #15 (permalink)
Old 11-29-2006, 07:21 PM
upncoming's Avatar
upncoming
Send a message via AIM to upncoming Send a message via Yahoo to upncoming
what kinda fridge did you use?
D.I.L.U.S.I.
Drive It Like You Stole It
  #16 (permalink)
Old 12-02-2006, 09:15 AM
Forget the name/brand but it was new in 1990. It had a plastic liner and foam insulation. Removed both and was good to go.
Ken
  #17 (permalink)
Old 12-02-2006, 04:55 PM
upncoming's Avatar
upncoming
was it a freezer / fridge or just a full fridge? these seems like a good idea but my buddy is saying he wants to make one out of wood and insolate it but i think hes crazy for think a few piees of wood can be placed and lined and be ok.
is there any pics you can post up?
D.I.L.U.S.I.
  #18 (permalink)
Old 12-03-2006, 01:51 AM
It was a freezer/fridge. Simply opened the bend of the metal on both the bottom of the freezer door and the top of the fridge door and pop riveted them together.
Yeah I'll post a few pics of the steps along the way.
Ken.
I'll add them in a bit.
  #19 (permalink)
Old 12-03-2006, 02:06 AM
Okay here is the step by step process I took to do this. Here goes.
Ken
First the original fridge.
Then I removed the guts and plastic liner.
  #20 (permalink)
Old 12-03-2006, 02:09 AM
That leaves you with foam and more foam. Doors were just hacked out with screwdrivers/putty knives. The body I got a little more aggressive with.
