Wow, what a lot of information on this site. I've been browsing as a 'guest' for quite some time and I think I'm finally ready to build a decent oven. Being my fist post I'd like to thank everyone for the information that they have already given me!
Here is what I plan to build, with questions to follow: 4' Wide x 8' Long x 4' Tall (Top Loader) 20ga CRS Inside & Out 2"x4" Metal Studs 4" Mineral Wool (To Fill Walls Completly) 1 - 1550rpm 8" Circulating Fan (To Circulate the air inside) 2 - Light Bulbs (One on each end) 1 - Digital Thermometer ? Elements ? Thermostat I currently have an oven(s) that I use to do smaller parts, basically two conventional ovens put together side by side. There are two bake elements and 2 broil elements. I never use the broil elements b/c I never needed them. Is there any way to tell what size elements they are? Will these 4 elements be enough for this size of oven (128sq/ft)? Will the thermostat I am using now (out of the orginal oven), be adequate to run all 4 elements? I'm very new to the elements, watts, btu's, of ovens. A friend of mine is a very good electrical guy and wired my current oven. |
Whats do you suggest I should use in a 4'x8'x4' oven for heating?
I'm running a 60amp breaker. I would like to keep it down to two elements but would run more if needed. I can find anywhere to get that fan from grainger that I was planning on using. Anyone know where I can get a motor and blade at that will be sufficent for this oven size? Thanks in advance! |
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
I puchased 3 each of the 3100 watt elements, hopefully this will get me close enough and not take forever.
I had a couple of questions above that no one has replied to and figured I'd do a little refresh on them: The thermostat that I'm currently using in my fat oven (not pregnant, lol), will it work with 3 3100W elements? Anyone know where I can get the fan/blade that will work for this temp, and be sufficent for my application? Last edited by itsallgood; 07-07-2006 at 11:14 PM. |
http://www.tempco.com/controls/thermo_bulb&cap.htm start there .. i have their unit installed and it works great.. just pick the temp range... my unit range is from 100 to 550 and is DPST it controls the contactor and the light in the oven as well as an "on" pilot light.
As for the fan blade.. just go to your nearest appliance parts store.. they have all types of fan blades. thats where i got mine.
If it jams; Force it. And if it breaks it needed replacing anyway. I can go from 0 to "What seems to be the problem Officer?" in 3 seconds." Last edited by KZjim; 07-16-2006 at 02:18 PM. |
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 03:43 PM |
| Wiring a simple two element oven... | wamontgomery | Oven Building Forum | 1 | 03-19-2006 02:49 PM |
| oven broiler element ? | buzzurd | Powder Coating Questions | 2 | 07-24-2004 10:43 PM |
| Custom oven material and heating element help needed | DarinReiss | Oven Building Forum | 13 | 12-27-2003 09:24 PM |
| Curing multiple parts of varying size in oven at same time?? | Fireblade | Powder Coating Questions | 3 | 09-28-2003 08:10 AM |
