+ Reply to Thread
Results 1 to 4 of 4
Thread: Insulation mistake ???
  1. Join Date
    Apr 2006
    Posts
    60
    I have been building a new oven 2x3x6. I have used metal studs with 22. gauge steel sheets to cover it. but I might have made a mistake using R20 Insulation (6") is this Insulation to big to fit in-between the oven walls? should I drill all the rivets off and re-insulation with the proper size? Please help i would like to start coating soon
    Share with Facebook
  2. Re: Insulation mistake ???
    Probably. Packing it to tight reduces the insulating factor. I would go and get insulation that is 3 5/8" thick. Will fit nice between the inner and outer walls. You can use what you have by tearing it and stuffing it into the panels. Pack it loosely but full, untill you get a thickness of about the stud depth. Compressing it a little won't hurt. Good luck.
    Ken
    Whoops, I didn't see you had it done. Try it see how it works. Test random spots with the infra red thermometer.
    Share with Facebook
  3. Join Date
    Apr 2006
    Posts
    60
    Thanks for the reply. The side walls have already been finished with 6" insulation, but I am going to insulation the top and door with the proper size insulation. I just hope the side walls are not going to be a problem
    Share with Facebook
  4. Re: Insulation mistake ???
    How did everything turn out?
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Insulation
    By FoxRider1488 in forum Oven Building Forum
    Last Post: 06-28-2006, 09:55 PM
  2. insulation help
    By gaskincrew in forum Oven Building Forum
    Last Post: 05-19-2006, 12:34 AM
  3. Insulation Thickness
    By KZjim in forum Oven Building Forum
    Last Post: 04-15-2006, 02:13 PM
  4. insulation and torpedo heater ?
    By bryceballard in forum Powder Coating Questions
    Last Post: 06-26-2005, 10:40 PM
  5. Totally off topic question about Insulation
    By tomg552001 in forum Other Metal Finishing Questions
    Last Post: 12-26-2003, 02:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
