http://www.powdercoatoven.4t.com/Index.html
http://www.f-5performance.com/powderoven.htm http://www.buy.com/prod/CH44X5043_45.../90143044.html http://www.famousparts.com/c25bnf240aco.html http://www.heatershop.com/btu_calculator.htm These should get you started. Ken Last edited by Hobweld; 07-17-2006 at 12:12 PM. |
I doubt it. Safer to use a contactor. It isolates the thermostat from the elements. Easy to hook up. The thermostat actuates the coil that opens and closes the contacts to the elements. That way your not pulling all that amperage throug the thermostat. Good luckl.
Ken |
I built a nice 4x4x6 foot oven with all the bells and wistles for about $1600. I used 18 ga. aluminized aluminum for the interior, 4" slag wool insulation, 20 ga. cold rolled for the outside. I have a sight window from a local appliance parts supply house. He got me three 5600 watt industrial oven elements @45.00 each which are twice the diameter of a household one which he told me I should get many years service from. I got my contactor which is a 70 amp three pole with a 120 coil of ebay for 15.99 new in the box. I also found a great digital temp controller on ebay for around 30.00 each and the same guy had thermocouplers for around 10.00. The appliance guy found me a walk in cooler door latch for 32.00 which makes it a breeze to get into mey oven when my hands are full. All these parts are readily available and if you want I can get you some brand names and part numbers. Hope all this helps!!!
