Old 07-17-2006, 08:50 AM
wamontgomery
Default Forced air heater thermostat?
Well, I have a 100k btu kerosene heater that powers my oven at the moment. Is there any kind of thermostat that would work for this, that has the heater turn off at like 400 degrees, and turn back on when it falls below like 375 or something? Thanks.
Old 07-17-2006, 03:09 PM
Aardvark's Avatar
Aardvark
Default Re: Forced air heater thermostat?
Pick one up from Ebay- look for a digital temp controller using a relay that you can wire the heater into. This is not the cheapest way but I haven't found a better option... I had to remove the factory installed t-stat on mine because it wouldnt work when the temp is 100 degrees outside....
tank heater rubber ends deteriorating TOMB Electroplating Questions 3 10-27-2008 06:35 PM
Air agitation or pump? rick201 Anodizing Questions 2 04-19-2006 02:04 AM
Sandblasting and prepping, newb help me! emopunk96 Powder Coating Questions 15 04-18-2006 01:53 PM
insulation and torpedo heater ? bryceballard Powder Coating Questions 1 06-26-2005 11:40 PM
powder coating near propane heater? randygrapes218 Powder Coating Questions 3 12-16-2004 10:05 AM
