Started my new oven..
It will be 4'x4'x6' started frame , it will be 2''x2'' steel box tubing. 2'' mineral wool insulation from McMASTER CARR . right now i just have the frame tack welded. I will update with pics and info as i go.. any suggestions on what heating elements are best to use for this size oven ? I need to stay below 60-amps if possible. Here's a frame pic so far..
http://www.HP-Powdercoatings.com |
looking good bro. as for elements i cant say where to get them but this calculator will help you size them for the oven http://www.heatershop.com/btu_calculator.htm
at 400 degree rise in temp 7000watts of elements should be enough and that should give you a 32 amp draw. most oven elements i have seen come in the 2000-3000 watt range so 3 2500 watts would be 7500, more than enough. that would be a 35 amp draw and you can run that on a 40 amp circuit for a almost 20 percent safety factor. hope this helps. best of luck bro.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
I got the frame all welded up tonight , just need to ad a few more braces in the bottom ,one on each side and the back. and ad a heavy duty one in middle on the top to hang parts (cycle frames) from.
also got the door frame done. I did the door with 1''x2'' box tubing. calling tomorrow to order my sheetmetal . here's a door frame pic..
update pic..
got the frame & door frame done. finished the sheetmetal and insulation on the top , bottom and back..
More progress....
Latest pic update..
finally got most of my electrical parts. hope to have it baking soon..
looking good, keep us posted on the details!
Thanks.. Here's a pic of my recirculation fan setup. I have about $15 in parts, got the fan free from a buddie who works for HVAC company. And a pic of a removable lower rack i made . ![]() ![]() Still need to install the elements and all the wiring. thats if i can ever find the correct wiring diagram for the "EBAY'' controller/contactor/thermocoupler that "STAN" sells..
Couple updated pics of inside.. elements mounted..
| Cooking up an oven project... | dagobert | Powder Coating Questions | 33 | 06-09-2008 04:43 PM |
| Sho Me Coatings Custom Oven | Livinincolor | Oven Building Forum | 21 | 10-16-2006 03:04 PM |
| CFM needed for 4x4x6 oven? | edwardpic | Oven Building Forum | 15 | 07-18-2006 04:55 PM |
| Oven problem !!!!! | tavo1765 | Powder Coating Questions | 7 | 10-06-2005 06:21 PM |
