Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Closed Thread
Old 09-22-2006, 11:30 PM
gaskincrew is on a distinguished road
Default what to use for switch help quickly please
i have a 50amp termostat,my question is what type of switch can i use ,will a household oven bake-broil switch work wired with my termostat
Old 09-23-2006, 06:51 AM
Default Re: what to use for switch help quickly please
Is your thermostat acctually able to switch 50 amps Are you asking what kind of MAIN off/on switch to use? If you have a rated Tstat to do the job, then just use the sircut breaker that feeds the oven? That's what I do. Or else, you can have a remote 60 amp switch installed, but there pretty pricy.
But, in reality, if you have a control device controlling the high heating current, and your htermostat runs off 120Volt(like contactors do) then you just need a light switch to supply the T stat voltage that will, in turn controll the contactor to heat the elements.
Home ranges are usually rated for 30 amps
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Closed Thread
zinc plate nuts&bolts during restoration (quickly) mikeyr Electroplating Questions 0 02-17-2004 03:55 AM
Polishing aluminum quickly? buckeyevs Metal Polishing Questions 2 11-06-2003 11:51 AM
