+ Reply to Thread
Page 2 of 8
FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 71
Thread: cheap excellent material for oven walls
  1. #11
    Default Re: cheap excellent material for oven walls
    cant find it online at homedepot, but here is what lowes shows.
    Hardibacker 3' x 5' x 1/4" Ceramic Tile Backerboard
    Item # 11640
    Model # 220001
    $10.98
    Same stuff??
    Vintage Speedwerks
    Custom Vinyl Graphics and Vintage VWs
    Share with Facebook
  2. #12
    Join Date
    Jul 2005
    Posts
    87
    yep same stuff
    Share with Facebook
  3. #13
    i am not building an oven, but wanted to comment. I was using a track torch to cut some 1/4 inch steel diamond plate. The plate was already in place, so 3 inches under needed to be protected. the hardi backer worked for 20 feet of direct oxy torch 3 inches above.
    Don't know if this helps, just my experance.
    Share with Facebook
  4. #14
    Join Date
    Jun 2006
    Posts
    620
    3" AWAY slag blast. Wow, that's pretty impressive acctually. I feel much better about getting hardi for my oven interior
    Dan Pesonen
    Forest Grove, BC Canada
    Personal motto:
    Share with Facebook
  5. #15
    Join Date
    Jan 2004
    Posts
    277
    I would caution you on one thing when using the backerboard. This is a compressed fiber product which means that it will create it's own dust. I would suggest sealing the surface to make sure that loose fibers don't get into you freshly coated parts. Personally I would be tempted to use ceramic to coat it as that will hold up to repeated heat cycles without a problem.
    Share with Facebook
  6. #16
    anybody have any problems with dust from this board?
    Share with Facebook
  7. #17
    im thinking about using it since sheet metal has gone through the roof. I priced some 18ga galvanided at 60 bucks a sheet. ouch!
    Share with Facebook
  8. #18
    Join Date
    Oct 2006
    Posts
    66
    It only took 3 1/2 sheets of 18g galv 4 x 10 to do the interior of my 4 x 4 x 4 oven. With a good amount of excess metal for a smaller oven. A little pricey, but I think the product will last longer. One of those; "Way the cost of initial expense vs repeated expense". Just my 2 pennies
    Share with Facebook
  9. #19
    Join Date
    Jun 2006
    Posts
    620
    I'm using Hardi Backer initially, then when money allows, I'll cover the hardi with light gauge tin. My oven is really raping my bank acct right now so If I can get it opperational, then tin the inside later, that will be best I think
    Dan Pesonen
    Personal motto:
    Share with Facebook
  10. #20
    Quote Originally Posted by Banditperformance
    I second this approach! I will be starting mine early next year and plan to do exactly what you are talking about. I am up for saving some money!
    Share with Facebook
+ Reply to Thread
Page 2 of 8
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
