  #51 (permalink)
Old 01-31-2007, 09:12 PM
TurboRoadster is on a distinguished road
Default Re: cheap excellent material for oven walls
Originally Posted by Waorani
Interested in hearing your results before I rip the hardiboard liner out of my oven. I had already bought some aluminum high temp paint but hadn't put it on yet given initial dissapointing results. Did you attempt to dry it out any before painting?
nope, but this was stored indoors and seemed pretty dry. I should be able to fire mine up for a test run tonight.
  #52 (permalink)
Old 02-01-2007, 05:18 PM
I fired it up for a test burn, all went well and 911 was not dialed at all
  #53 (permalink)
Old 09-17-2008, 02:07 PM
CoffeeInjection is on a distinguished road
Hello Everyone. I just stumbled across this forum as I did a material search for my new over build. There is a lot of good info here. Anyway, I do have some experience with Hardiboard. I can say that it does burn, but not very easily. After my garage project was done last winter, I was burning a pile of tree clippings, and I figured that I would try to burn the scrap Hardiboard panels. Guess what, they DO burn! They were the last bit of "wood" on the pile to burn, but after lying on the hot coals for a few hours, they eventually burned into ash. Some pieces didn't burn completely, and just turned into hard "tile" like material, but most of it burned. I'm not sure of the temperature of the fire/coals, but keep in mind that if you get the Hardiboard hot enough, it WILL eventually burn. I would definitely have a sheet metal barrier between the Hardiboard and the direct heat. Just my 2 cents.
Also, for anyone new to Hardiboard, make sure that you buy a saw blade that is made for cutting these panels, as it will burn up a standard saw blade like nothing else (I found this out the hard way). Plus, the concrete board blades will cut the Hardipanels with about half the effort. Also, be sure to wear a mask of some sort to keep from inhaling the released dust.
  #54 (permalink)
Old 09-18-2008, 10:07 PM
JTW37's Avatar
Caswell Platinum Member
Good info on the hardy board. And Welcome to the forum. Lots of info here and good help.
  #55 (permalink)
Old 09-20-2008, 01:54 AM
powder02 is on a distinguished road
i put that hardy board in my oven a year ago i put it just down on the floor it was good for a while i notice it starting to warp first then it started to break apart . if i were to do it again i think i would put the metal over it..as far as dust i cant really say i had at times specks of something never could figuard out where it came from..now im wondering if that wasnt it,fibers from the board
