Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions > Oven Building Forum
Connect with Facebook
Closed Thread
Old 10-28-2006, 02:27 PM
RNMHRD's Avatar
RNMHRD is on a distinguished road
Exclamation My oven SCHEMATIC...for new oven builders..
Just finished up my oven wiring , and oven works great !!
Here's the schematic i made up from how i wired my oven.
My oven is wired Single phase 240v .
Im using the Thermostat ,K-thermocoupler, and 40-amp contactor from "drill12" from EBAY.
http://cgi.ebay.com/ws/eBayISAPI.dll..._BIN_Stores_IT
SCHEMATIC PIC..
Old 10-29-2006, 02:31 AM
usmcmaw is on a distinguished road
Default Re: My oven SCHEMATIC...for new oven builders..
Thanks, you answered a question that I posted not log ago. I like the clarity of your drawing.
Old 11-06-2006, 01:50 AM
What size wire did you use between 2/T1...4?T2 and the heating elements.
Old 11-06-2006, 04:55 AM
The size of the wire will depend on the wattage of the elements. 14AWG is good for 15Amps max under the Canadian Electrical Code.
BUt, that's based on the insulation rating of standard home wire. The high temp wire does have different ratings. I am running 13 amps/element on 18AWG VHTW wires good to 650*C 1200*F
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 11-06-2006, 11:31 AM
RNMHRD's Avatar
Exclamation Re: My oven SCHEMATIC...for new oven builders..
I used 12 gauge stranded wire for elements.
Old 01-15-2007, 04:06 AM
muskie's Avatar
muskie is on a distinguished road
I got the controller off of drills also. mine seems to take a "J" type thermocouple. this make any difference to your set up? and how did you mount your controller to the oven? thanks
Old 01-15-2007, 02:54 PM
RNMHRD's Avatar
The "J" type is for more of a flush mount . You will need THe "K" thermocoupler That you can mount outside oven and goes into the oven 6"-10".
I just mounted the controller in a cheap electrical box on the front side of the oven.
Here's a pic.
thanks , TIM
  #8 (permalink)
Old 01-17-2007, 07:19 PM
TurboRoadster is on a distinguished road
eureka! answers to my questions !! thanks
I just sent an email for the goodies
what type of fan did you get and mind if I ask where?
  #9 (permalink)
Old 01-18-2007, 09:15 PM
vintagespeedwerks is on a distinguished road
so now that you have bought it, tell us some part numbers etc so we can find it CHEAPER.
ive seen similar looking ones for 30.00 but wasnt sure if its function was the same or not.
Vintage Speedwerks
Custom Vinyl Graphics and Vintage VWs
  #10 (permalink)
Old 02-14-2007, 03:56 PM
kcenicola is on a distinguished road
Here is a photo of the latest controller we built for a forum member. It drives two elements, lets you select between 1/2 and full oven power, has a digital micro controller, and an ammeter for showing current draw.
Ken Cenicola
NHA Supply, LLC
Closed Thread
Cooking up an oven project... dagobert Powder Coating Questions 33 06-09-2008 04:43 PM
new oven helstar Oven Building Forum 1 07-27-2006 07:43 AM
Oven problem !!!!! tavo1765 Powder Coating Questions 7 10-06-2005 06:21 PM
Oven Builders Help! PC4545 Powder Coating Questions 5 12-08-2004 06:17 PM
