Old 11-10-2006, 04:34 PM
holeshot87
Thumbs up propane heater
hi,i just got done building a oven. 6'Hx4'Dx3'W. i made a 8" hole at the bottom of my oven and plan on using a propane heater. the heater will be at the end of a 2' peice of tubing. is this safe or do i have to put something at the end of the tube. aslo is there something i can use that will shut the heater off when it get to the the right temp and ignite the heater when it gets below said 400. thx jim
Old 11-13-2006, 02:51 PM
holeshot87
Default Re: propane heater
well i guess no one can help me. thx anyway
Old 11-13-2006, 05:34 PM
krusty2111us is on a distinguished road
I don't know too much about gas heated ovens. I do know you need some type of heat transfer system, like in your home heating system, to isolate direct flame contact with any possible fumes or components in your oven.
Old 11-13-2006, 05:46 PM
Ya, I would be VERY carefull using flame heat. Powder in cloud form is explosive, and I am not 100% sure if the gasses given off bu curing are safe either. Like was stated, Professional ovens that use gas heat have a heat transfer, or they are assured in the design that the flame will never see combustables in the oven. Could be making a very big bomb
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 11-14-2006, 09:06 AM
holeshot87
thanks for the information. the propane heater will be a forced air type like a torpedo heater. will this work.
Old 11-15-2006, 01:18 PM
Holeshot, try this thread
new gas powered oven
He has made a gas oven from a torpedo heater. He would be the best one to get in touch with. SHoot him a PM
Dan Pesonen
Personal motto:
Old 11-19-2007, 03:46 AM
gomer950 is on a distinguished road
what btu ratings are you guys using for your propane heaters?
  #8 (permalink)
Old 11-21-2007, 10:18 AM
FigureLLC's Avatar
Caswell Platinum Member
i have NO idea if this would be helpful, but i thought i'd post it bc i rememberd coming across it... mcmaster-carr has a "remote heat controller":
"Just plug your heating equipment into one of these controllers and turn the adjustment knob to set. "On-off" cycling controls the amount of time a heater is on by proportioning electric power at line voltage. You should monitor your temperature with a separate thermometer. Controllers have a 6-ft. power cord with three-prong plug. Units operate on 115 VAC, and provide 115 VAC up to 1500 watts. The solid-state model reduces arcing of the switch contacts."
page 544 online catalog
Len
Figure Engineering, LLC
curing with propane heater kchotboat Powder Coating Questions 4 11-09-2007 10:55 AM
oven build/ elec IR/ or propane IR? Carcher7878 Oven Building Forum 8 04-06-2007 04:29 PM
advice on oven propane or electric RCC Powder Coating Questions 13 11-26-2006 09:57 PM
tank heater rubber ends deteriorating TOMB Electroplating Questions 1 10-03-2005 07:45 AM
powder coating near propane heater? randygrapes218 Powder Coating Questions 3 12-16-2004 09:05 AM
